Transmission & Drivetrain Gearboxes, Differentials, Clutches
Are these parts interchangable?
Old Aug 19, 2009 | 01:23 PM
twentyhurtz's Avatar
Default Are these parts interchangable?
hi,
i have a gs-r transmission that has some things wrong with it, and i may have to fix it with an old busted ls tranny sitting around with some good parts in it, i was wondering if these parts are interchangeable?
1. The gs-r i have has a bend shift rod, can the ls shift rod replace this?
2. Speed gears, do these interchange?
3. Reverse gear? do these interchange?
Old Aug 19, 2009 | 03:16 PM
Aquafina's Avatar
Default Re: Are these parts interchangable?
Shift rod = yes.
Speedo gear = yes.
There is no reverse gear. Mainshaft, 1/2 slider, reverse idler gear.
Old Aug 19, 2009 | 04:34 PM
wow short and sweet answers, but you say speedo gear? do you think i'm talking about the speed sensor? the mechanic at the shop that told me mine was bas said there are 3 of these that have gone bad and the slide under the other gears, i guess up and down? not sure, they are not visible just by taking the case off, so i'm not sure exactly which he is referring to.
Old Aug 25, 2009 | 01:16 PM
Aquafina's Avatar
Which gears? By speed gear I assume you meant the speedo gear that mounts onto the diff and spins the gear on the VSS.
turbo-crx
Nov 3, 2008 04:22 PM
Aquafina
Sep 6, 2008 11:14 PM
Preferio
Honda Motorcycles
Sep 16, 2007 11:05 AM
b20civic
Sep 8, 2002 11:33 PM
