im trying to find out what to add to a engine of a 1998 ex civic coupe
Old Aug 19, 2009 | 12:07 PM
vashtx's Avatar
Default im trying to find out what to add to a engine of a 1998 ex civic coupe
like what could i do to increase the acceleration, horsepower, handling, and even top speed
also can someone explain to me what a flywheel does for a car and please be simple with your answer im not exactly sure about what inertia means
also please explain to me what a strut bar, coil overs, and what a sway bar does and please again in simple terms
Old Aug 19, 2009 | 12:12 PM
95jeremie's Avatar
Default Re: im trying to find out what to add to a engine of a 1998 ex civic coupe
wow... search
https://honda-tech.com/search.php
Old Aug 19, 2009 | 12:17 PM
monster_ls/vtec's Avatar
the acceleration can be done by beefing up ur trans. to add horses headers and cold air will do it. a strut, and sway bar will help in handling the strut makes it so the frame is more stiff and so it dont flex... idk the rest of ur qustions but i hope it hellped a little.
Old Aug 19, 2009 | 12:19 PM
95jeremie's Avatar
there is more to it than that
yall need to throw a research party
don't think your just going to throw some parts at it and get what you want
Old Aug 19, 2009 | 12:20 PM
Skip01's Avatar
You not gonna see much gain with boltons, maybe 8hp or so.
But yes do search, heck even search wiki for the suspension questions
Old Aug 19, 2009 | 12:21 PM
lol he said plain and short thats wat he got
Old Aug 19, 2009 | 12:22 PM
vashtx's Avatar
i did think i forgot to add that if you have any more i can add to it please tell me
i will admit thyeres alot more to search
Old Aug 19, 2009 | 12:24 PM
www.megameet.org's Avatar
sounds like you need to buy a used car that is already done up the right way from someone on here. My wife knows more than you. I dont want you to get screwed. You need to do research and read!
vashtx's Avatar
well anything will be useful i just dont want anything thats gonna tear it up like turbo or supercharger
Old Aug 19, 2009 | 12:25 PM
infinitypro12's Avatar
First of all if you want best bang for your overall bucks invest in a new engine. Don't get me wrong, I appreciate D-series but you want to look into B or K series which are popular. B-series is a little easier to do for some one new to do in my opinion.
If you just want the best out of what you have then:
- Air intake upgrade or replacement.
- Replace suspension and do the sway bars while your at it.
- Upper strut bars are cake.
- Get better headers, piping, and overall exhaust flow.
- and the list is pretty general and you get the idea.
As for the rest you will just have to research and google your @$$ off. Don't both with the search function on HT because it takes forever to find what you need, google is way better.
Also, give the FAQ section a glance and howstuffworks.com, no kidding.
95jeremie's Avatar
acceleration NA research light weight fly wheels
HP research motor mods/ rebuilds or FI
handling research suspention mods
Old Aug 19, 2009 | 12:27 PM
95jeremie's Avatar
search function works just fine
you just gotta be smarter than the beast
Old Aug 19, 2009 | 12:32 PM
vashtx's Avatar
so about how much would a b series engine cost?
Old Aug 19, 2009 | 12:35 PM
95jeremie's Avatar
as little as you know.... a LOT
Old Aug 19, 2009 | 12:39 PM
vashtx's Avatar
well i know its alot but what im wondering is that my bro said it would cost around 6000 but i dont kno if he talking about nearly a new one or it actually costs that so what would be better to buy the engine or just buy the car
RotaryPWR's Avatar
ya search and learn a bit
i'm guessing u have a d16y8. 3 options for power are engine swap, boosting (turbo, supercharge), and N/A (mentioned above were intake, headers, exhaust..u can also do internal work aka cylinders, and head work aka cams and valvetrain).
the n/a option is very pricey over time and will get u the least gains. turbo can give huge gains for cheap but if done wrong u will blow ur engine, and it will never be as fast/reliable as an equally modded b,h,f,k-series. swaps are expensive for not much power gains, but u get a much much better platform to work with.
if u haven't researched much, u may not understand this all super clearly..so get at it!!
just my .02
Old Aug 19, 2009 | 12:42 PM
RotaryPWR's Avatar
research swaps!! 6000 is too much..u can probably go k-series for that price..
it took me over a year to finally decide whether i wanted to swap or go turbo and to figure out a good budget and what power levels are right for me. we all researched a lot, so do some homework!!
first step is what do u want the car for? daily driver, autocross, drag strip, track racing, etc
Old Aug 19, 2009 | 12:48 PM
vashtx's Avatar
well i partly want it for a show car kind of in a way but its gonna be my daily driver and i might do some drag races but im not going to make it a straight out just for dragging car
Old Aug 19, 2009 | 12:54 PM
Pothole987's Avatar
4 cylinder hondas only have 1 exhaust manifold so its HEADER . no 's' big pet peeve of mine.
for a DD i've recomend going all motor no turbo or S/c. you can pick up a B20 and get a Vtec head and make a CRvtec for under 3 grand (others doing the work of course)
but if i where you, don't waste money on boltons. because most you get will only fit the d series. my .02. swap for dd use. and don't say a s/c or turbo will be reliable because the more parts you add on the more parts are going to fail. been there done that.
Old Aug 19, 2009 | 01:02 PM
95jeremie's Avatar
just for the record
I'm sohc na coup
and i run dohc coups and hatches all the time and wax their asses...
i's not hard or expensive to build a sohc to run with the dohc's
raffydogg
Jul 15, 2008 02:04 PM
eternity0
Suspension & Brakes
May 9, 2006 11:53 AM
VSM_EK
Suspension & Brakes
Apr 4, 2006 12:18 PM
AccordCD5
Mar 17, 2004 07:24 PM
94HybridEX
Apr 30, 2003 01:07 PM
