fully built head cam problem
Old Aug 19, 2009 | 11:52 AM
gsr-da's Avatar
Default fully built head cam problem
i have a 90 integra with a 98 gsr
p30 pistons
tri header
hks exhaust
cometic 2 layer hg
golden eagle head studs
ported and polished head 3 angle valve job
super tech high comp valves
super tech dual valve sping and retainers
blox intake manifold w/68mm bdl throttle body
p72 with hondata s300 will get it tuned when done
i was thinkin about goin with the skunk2 pro 1 cams i just want someone elses opinion because im sure some one has done this build before
trying to get about 180-190 whp
thanks
Old Aug 19, 2009 | 11:55 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: fully built head cam problem
Check the all motor dyno thread at the top of the forum.
Old Aug 19, 2009 | 12:24 PM
MKTurismo's Avatar
So whats the cam problem???
Old Aug 19, 2009 | 07:43 PM
gsr-da's Avatar
the problem is that i dont know for sure what cams i should buy thats why i kinda was asking for some opinons
Old Aug 19, 2009 | 08:21 PM
Top Ramen's Avatar
What does that give you, 11.6 to 1 (or so) compression? A bit low for Pro1s, but they would work.
It would help to know what your priorities are - peak hp, mid-range, whatever.
Old Aug 20, 2009 | 07:34 AM
skunk2chris's Avatar
If you do decide to go with Pro 1's, make sure you check your clearances. I say this cause P30 pistons, along with the rest of the other OEM pistons have very shallow valve pockets which could cause P2V clearance issues. I strongly recommend degreeing the cams in and maybe even claying the motor.
Cheers!
stupid fast
11
Mar 25, 2015 07:45 AM
marshall12395
15
Feb 18, 2013 07:19 AM
green_eg_hatch
Jan 23, 2010 04:21 PM
b18sihatch
Jun 16, 2006 09:59 AM
