clutch line replacement
Old Aug 19, 2009 | 10:26 AM
y2kferari's Avatar
Default clutch line replacement
I have a 94 ex w/ hydro tranny. The rubber clutch line that is attached to the slave cylinder(its about 6 inches long), is leaking. Well I ordered the line from honda. But when I tried to change it out, I used all my strength on breaking the couplers off(with a 12mm and 10mm wrenches, which are the bolt sizes holding the couplers on). But I started twisting my metal clutch lines before I starting breaking or budging either of the bolts. Idk if there is some like secret or something thats keeping it from giving. Anyone have an idea?
Old Aug 19, 2009 | 10:29 AM
95jeremie's Avatar
Default Re: clutch line replacement
line wrenches
Old Aug 19, 2009 | 10:30 AM
95jeremie's Avatar
http://autorepair.about.com/od/tools..._line-wren.htm
y2kferari's Avatar
Originally Posted by 95jeremie
line wrenches
I dont think that would make that much of a difference, huh?
Old Aug 19, 2009 | 10:31 AM
95jeremie's Avatar
the pic is of 12 pt.
your going to want 6 pt.
95jeremie's Avatar
it will
Old Aug 19, 2009 | 10:32 AM
95jeremie's Avatar
and PB Blaster ha ha
Old Aug 19, 2009 | 10:34 AM
y2kferari's Avatar
well that was the problem I was having, the wrench gripping. so it prollly will fix my problem, thank you so much sir
Former User's Avatar
Did you try using two flare wrenches with a scissor-like squeeze action to break the nuts loose?
Old Aug 19, 2009 | 10:36 AM
95jeremie's Avatar
ron
how many manuals do you have ha ha
kick *** pic
Old Aug 19, 2009 | 10:38 AM
y2kferari's Avatar
nope. just standard open face wrenches
Old Aug 19, 2009 | 10:40 AM
ron
kick *** pic
Too many.
I see you already addressed the flare/line wrench and PB Blaster solutions. The one-handed squeeze action of two properly placed wrenches should be the final bit of needed information.
Old Aug 19, 2009 | 10:42 AM
Those also may work, but the flare wrenches will reduce the chances of stripping the nuts.
Freedo_Civegra
Acura TSX
Feb 18, 2018 06:53 PM
t3to4e
Jun 29, 2006 03:14 AM
integrasi
Aug 26, 2004 09:29 AM
KillaB-
Aug 22, 2004 08:13 AM
