Very Bumpy Ride, please help
Old Aug 19, 2009 | 08:26 AM
sketchman's Avatar
New User
Default Very Bumpy Ride, please help
Hello,
I've had a problem with my V6 '00 Accord coupe. When riding over bumps, the feeling is very uncomfortable. For example, a road that has had repairs to it (with that asphalt junk), when riding over them, the feeling is very bumpy/harsh.
I went to the mechanic and he replaced my struts. I figured that would do it but when I ride around, the car still feels the same.
When I first got my car, I used to ride over bumps or anything and it would feel "soft" and comfortable. Now it is so rigid and uncomfortable.
I've had other people ride in my car and by the feeling they said I should change my "shocks". This was after I changed my struts.
Any suggestions or ideas? I know this isn't normal but the mechanic keeps saying everything is fine. It is driving me crazy because I spend $700 to replace the struts and it doesn't feel any better at all! I feel like, if the struts weren't the problem, why did he replace them!!
Thanks!
Old Aug 19, 2009 | 09:47 AM
P_Adams's Avatar
Default Re: Very Bumpy Ride, please help
Originally Posted by sketchman
Hello,
Thanks!
Does it feel like the suspension is bottoming?
No lowering kit, right?
What brand struts?
P
Old Aug 20, 2009 | 08:45 AM
sketchman's Avatar
New User
Thanks for the reply.
I'm not sure what brand of struts, but he usually orders parts from the dealer.
I haven't lowered my car or really done anything extra to it.
I'm not sure what bottoming is. It just feels like the whole car moves when I hit a bump. In my other Accord, when I ride over bumps, it feels soft and comfortable. The good accord doesn't make any extra noise when going over bumps. On the one that is the problem, the same bumps feel like the whole car is moving and there is much more noise.
Old Aug 20, 2009 | 09:42 AM
P_Adams's Avatar
Does it feel like it's wandering while this is going on; like the suspension is loose? This is a tough one without road testing it......
Do you get a knocking sensation thru the steering wheel while this is going on?
P
Old Aug 20, 2009 | 12:39 PM
philadd's Avatar
P
That was my first thought as well.
sketchman, where are you located? Maybe someone on the board is local to you that would be willing to go for a road test with you.
In regards to the mechanic replacing the struts... When diagnosing problems, the mechanic often times has to take his best (and usually educated) guess. Unfortunately, that means that there will be times where a part, or parts, will be replaced without resolving the problem. In most cases, you get stuck with the bill.
Old Aug 26, 2009 | 03:24 PM
KaiKasei's Avatar
maybe your shocks are out or your springs are bad go out to your car and push down on it the suspension is suppose to be stiff so if you can easily push down and make it jump then your suspension's bad
kixcrx
Dec 19, 2006 12:13 AM
dblock2x
Suspension & Brakes
20
Jan 31, 2006 11:00 AM
eight grand
Sep 29, 2003 02:33 PM
AMG
Apr 3, 2003 10:00 AM
Blue-Civic-Hybrid
Jun 25, 2002 11:30 PM
