crx gas mileage
Old Aug 19, 2009 | 05:16 AM
sepheroth's Avatar
Default crx gas mileage
I picked up a 90 HF not long ago. I installed new plugs, airfilter, oil, tranny fluid, fuel filter (the spark plug wires look good). Im only getting 30-33 miles a gallon whats up with that?
why would I get such bad mileage? timing is off maby?
Also my mechanic had to cheat it to get it to pass emissions, I think its running way rich.
code 10 is going off under the carpet which has to do with intake air temp.
Old Aug 19, 2009 | 06:22 AM
pandarex's Avatar
Default Re: crx gas mileage
maybe your iat is bad. that could be a big part of your gas mileage problem. and your mechanic should have checked timing, and should have probably told you to get a new iat or at least check to see if its functioning.
Old Aug 19, 2009 | 06:50 AM
sepheroth's Avatar
what is an iat
Old Aug 19, 2009 | 11:12 AM
dephtone's Avatar
Air intake Temp Sensor. It is on the runner #1 closest to the timing belt. It's on the side of the intake manifold. It's a white sensor with a 2 prong plug.
Old Aug 19, 2009 | 05:41 PM
sepheroth's Avatar
how would I check if its bad?
Alex98
Apr 12, 2019 05:04 PM
pintobean11
56
Aug 24, 2011 03:01 PM
743power
Dec 11, 2005 07:28 PM
DA9_DAD
Jan 25, 2005 12:33 PM
mickey513
Feb 1, 2003 02:51 AM
