vafc and msd btm
Old Aug 25, 2002 | 08:47 PM
td04civic's Avatar
Default vafc and msd btm
i'm building a d16z6 motor to run 15psi of boost. Would a vafc and msd btm be enough to tune the car. I noticed they don't make a hondata or aem ems for the 91 crx ecu which is the one i'll be using. Thanks
Old Nov 26, 2002 | 08:22 PM
CzanSOHC's Avatar
Default Re: vafc and msd btm (td04civic)
no.
Old Nov 26, 2002 | 08:29 PM
Kataku2K3's Avatar
Default Re: vafc and msd btm (CzanSOHC)
I would just convert to OBD1 and run Hondata... You would probably be able to get away with a VAFC up until maybe 8psi or so... After that you'll want something like Hondata... Good Luck
Old Nov 26, 2002 | 09:48 PM
d-wreck's Avatar
Default Re: vafc and msd btm (JDMspecEG6)
just get a p28 ecu and convert to obd1, plus then you dont have to convert your existing ecu to hit vtec.
and 15lbs of boost is goinging to take magagement. hondata
vafc is mostly a tuning tool not a management tool, but it can replicate one sometimes
derek
lopey
Nov 12, 2005 05:38 AM
tub_sephiroth
Dec 5, 2004 07:53 PM
pootie.teng
Jan 22, 2004 11:40 AM
daddymaxx
Nov 21, 2003 12:44 PM
HX_Guy
Jan 1, 2002 03:14 AM
