LCA Question
Which rear LCAs can I used that will allow me to use a set of koni yellows that came off a 98 civic? I have an 89 si, I figured they should bolt up, but the LCA bushing is too wide for the shock.
Won't work out that way for you since the bushing width on the ek's are slimmer. Unless your konis use washers to accomodate the slimmer size, then you can't use any lca's since 98 lca just won't work either.
Yah, I know they won't work. But I'm going to do a rear disc brake conversion right away and was wonder which LCAs I could use to make them fit. I'm guessing 99-00 civic si? Anything else, those rear disc swaps are harder to find.
normally should be fine as long as u use ef,da, eg or dc2 lcas... sold my crx agx to a friend with a 2000 dx coupe... he needed crx front forks and for the rear he had to run spacers on both sides of the inner sides of the rear shock's fork (beacuse the metal sleeve in the bushing is shorter on em/ek rear lcas) so with that said in your case as long as you use lcas from one of those forementioned chasis, you shouldnt need the spacers. BUT unlike kyb or tokico i guess koni actually makes the fork slimmer too instead of giving you spacers so if thats the case, you just cant "bolt em up" with any lca... maybe u can buy just the bushings u need.
vbphreak
Mar 16, 2005 06:13 AM
SE7EN3S
Aug 31, 2004 05:32 PM
