need help! speedometer and odometer issue...
Old Aug 18, 2009 | 08:11 PM
pacey's Avatar
Default need help! speedometer and odometer issue...
my speedometer and odometer suddenly stopped working when i was driving home and the check engine light was on.. what should i do? please help.. thanks!
Old Aug 18, 2009 | 08:30 PM
jcdimvic's Avatar
Default Re: need help! speedometer and odometer issue...
what year is it?
Old Aug 18, 2009 | 08:41 PM
bandit67's Avatar
The check engine light prolly came on due to speedometer not working. If you do not have a blown fuse then I would look at the vehicle speed sensor on the tranny. My speed/odomemeter quite working due to a faulty headlight switch on the colume.
Old Aug 18, 2009 | 09:23 PM
pacey's Avatar
its a 2000 si.. i checked the fuse already but i think its fine.. i also unplugged the harness on the vss and on my cluster and plug it again but its still not working..
Old Aug 18, 2009 | 09:30 PM
slow96lude's Avatar
it is definatly a fuse. its the 7.5 amp fuse #15 i believe.
Old Aug 18, 2009 | 09:35 PM
pacey's Avatar
i checked the fuse already.. and its still looks fine..
Former User's Avatar
Pull the CEL code and post it.
Old Aug 18, 2009 | 10:01 PM
boxeocampeon's Avatar
Your speed sensor probably went out but thats weird that the CEL came on
Old Aug 18, 2009 | 10:26 PM
pacey's Avatar
Found it.. at last!! its the no. 15 fuse.. i guess when i checked it i pulled the wrong fuse.. stupid me.. lol! but thanks guys! your guys are big help! thanks again!
Old Aug 18, 2009 | 10:28 PM
If the new fuse #15 blows again, click here.
Old Aug 18, 2009 | 10:48 PM
pacey's Avatar
so why do you think that happen? is it just because something is grounded? hopefully when i get the new fuse it wont blow up again.. thanks again man!
Old Aug 18, 2009 | 10:51 PM
Not sure, but maybe the fuse won't blow again because I don't think the 00 Si is included in the TSB I posted.
Old Aug 18, 2009 | 11:24 PM
pacey's Avatar
ok hopefully not.. and thanks again!
CiViCShella
May 2, 2013 01:44 PM
pang_yeng
21
Nov 24, 2011 05:52 AM
Devious951
10
Aug 29, 2009 10:22 AM
delsolcrazy
May 5, 2005 03:06 PM
TodaR
Jan 21, 2004 03:16 PM
