Huge Garage Sale, OEM,DC,EG,EK,Suspension,Trans, NJ
I'm cleaning my garage. Everything is listed below. Prices are SOMEWHAT Negotiable. If it does'nt have pics then I'm not able to take pics of it. Located off exit 129 on the Garden State Parkway. I will ship if buyer pays for it and includes Paypal fees.
Will only trade for:
Del Sol Drivers side fender(Any color, Paint could be shitty too, just NO DENTS)
OBD1 SOHC Fuel Rail (OEM Or Aftermarket)
Open ended extended lugs (Gold Or Black)
Shifters And Linkage
2000 Integra GSR Dual Bend Shifter-$30
OEM Civic Del Sol Shifter (If you dont know its a really short throw shifter with a bend towards the driver, Not like Egay ****)-$35
Civic Single Cam Shift Linkage-$30 With Stock Shifter
Suspension
2000 Integra GSR Stock Springs-$40
Neuspeed Green Springs All 4 -3"F-2.75"R( Front 2 Are On EK Struts Rear On Nothing)- $125
BRAND NEW Skunk2 Lowering Springs 92-00 Civic F-2.5 R-2.25" Drop-$125
Engine Parts And Mounts
OEM 2000 Civic SI Transmission Mount Bracket-$25
OEM SOHC Civic Rear T Bracket- $20
Holley EFI External Fuel Pump With Fram Filter-$75
Integra Fuel Filter With Bracket -$15
90-95 Integra LS Valve Cover Have 2 (1 Stripped to bare metal)-$25
D16Y8 (SOHC VTEC) Intake Mani With TB- $75
Transmission Parts And Acc.
90-93 Integra 5 Spd Cable HalfShaft-$50
SOHC Hydro Axles- $50 For Both
B Series Hydro Clutch Fork-$15
SOHC Hyrdo Clutch Fork-$15
2000 Integra GSR Countershaft, 1st Gear and Final Drive-$100
95 Integra GSR Countershaft and mainshaft (With Good gears, Needs Mainshaft syncrhos), And Final Drive-$125
B series Hydro Outer Trans Casing (Not the part with the VIN plate)-$80
Electronics And Wiring
OBD1 Engine Harness, Not hacked up or anything Non Vtec-$60
Wideband o2 Sensor With Wiring Clip (Not Sure For Which Wideband)-$30
Chipped OBD1 P75-$120 (Crome Chipped, Will include a basemap for you)
Exterior Parts
98-01 Integra Clear Bumper Lights New- $20
93-97 Del Sol Tail Light Garnish USDM Milano Red (MINT)- $40
( The metal part the license plate mounts to)
Aftermarket Fogs(Were Ion Blue, Sprayed over with yellow) Could Fit EK/Delsol-$30
Interior parts
94-01 Integra Rear View Mirror-$15
Integra Type R BRAND NEW SPEEDO (Not Cluster Just Speedo)-$100 OBO Retails for a shitload more.
AutoMeter 5" Phantom tach With Shift Light (Black with White face and black lettering- $100 MINT
92-95 Civic 94-00 Integra Stock OEM Shift Boot (Clean)-$10
93-97 Del Sol Console Vents- $10
Turbo Parts
Tial 14LB Wastegate spring (New)-$15
Tial 38MM Fire Ring (New)-$25
4 Bolt 2.5 Inch Downpipe (For EG/DC/EK W/ B series)- $65
Random Stuff
EG/EK AC Condensor And Fan- $50 Mint
Single Cam AC Compressor- SOLD
EG/EK Maybe DC AC Hardlines, Lines to compressor, And Canister-$35
Suspension
Exterior Parts
Interior parts
Turbo Parts
Random Stuff
DownShiftPerformDC2
Aug 21, 2009 01:55 AM
mr_mbuna
27
Nov 18, 2002 08:39 AM
