Redline at 6500 rpm and no V-TEC
Old Aug 25, 2002 | 08:14 PM
purpl7duece's Avatar
Default Redline at 6500 rpm and no V-TEC
I have a H22a4 with a GSR ECU in my 92 accord and the V-TEC should come on at 5000 RPM. Since last night when I hit 6500rpm the hit the rev limiter came on. I usually take it to 7500 when I race. I can't get over 6500 cause it sounds like the rev limiter kicks in at 6500 and it is not getting V-TEC either. Last night I went to the carwash and washed my motor with the pressure washer. I think I might have undone a wire but I don't know. Does any one know what could cause this. Any help would be appreciated.
Old Aug 25, 2002 | 08:23 PM
wutangben's Avatar
Default Re: Redline at 6500 rpm and no V-TEC (purpl7duece)
first thing i would check is your oil. go check it and then we'll go from there.
peace
Old Aug 25, 2002 | 08:29 PM
Nick M's Avatar
Default Re: Redline at 6500 rpm and no V-TEC (wutangben)
you are in "safe" or "limp" mode with an early redline like that, you must have a check engine light no?
Old Aug 25, 2002 | 08:47 PM
Default Re: Redline at 6500 rpm and no V-TEC (HondaSport)
Yeah the check engine light would always come on right after I haul *** but since last night is always comes on.
Old Aug 25, 2002 | 08:51 PM
PrecisionH23a's Avatar
gotta be careful when you pressure wash your engine bay, what i recommend is purchasing a sprayer that you use for spraying for bugs, it does the job and you can avoid wetting down electrical things. i would check to make sure you didnt disconnect any of your vtec wires, check near your vtec solenoid near your distributor. i dont know a lot about vtec since i run the h23a but i would have to say its either a disconnected wire or you got water inside of a solenoid or sensor. does your check engine light come on at all?
ok run the test wire to put your car in limp mode then tell us what code you pull. remember
1 long blink = 10
1 short blink = 1
Old Aug 25, 2002 | 08:58 PM
Default Re: Redline at 6500 rpm and no V-TEC (GudeH23a)
I have no idea how to put my car in limp mode. Is that when you count the blinks on the ECU?? My boy can do that but tomorrow.
[Modified by purpl7duece, 5:59 AM 8/26/2002]
Old Aug 25, 2002 | 09:02 PM
prelude1897's Avatar
Yeah, see what code you're throwing and then you can go from there to figure out whats wrong.
Old Aug 25, 2002 | 09:04 PM
Default Re: Redline at 6500 rpm and no V-TEC (prelude1897)
I will check in the morning. I NEED my V-TEC or else I will die.
Old Aug 25, 2002 | 10:13 PM
here is an article that will tell you exactly how to put it in limp mode, complete with pictures and everything
http://www.hondaprelude.to/main_checkengine.html
on your car the connector might be located in a different spot, swing by advanced or somewhere and look at the helms manual and find out where exactly it is
[Modified by GudeH23a, 2:14 AM 8/26/2002]
Old Aug 25, 2002 | 11:32 PM
EH2DX's Avatar
you mean VTEC not "V-TEC"
but anyhoo, the "limp mode" is not when you're counting the blinks, it's when there is a problem like a faulty sensor of some kind and your car wont go past 6500 RPM. think of it as a safety precaution. it will do the same if the car is cold.
like the guys said, run that code and go from there. good luck.
Zackary Harris
K Series
Sep 7, 2018 09:38 PM
jdmgeezer
13
Aug 19, 2011 05:49 AM
eg_ruoner364
Jun 22, 2008 07:23 PM
lsvtec hatch05
Apr 23, 2004 05:53 PM
philstireservice
Sep 27, 2003 04:01 PM
