iacv problem...i think, someone chime in!!!
ok, i got all my other problems sorted out, cleaned and adjusted the fitv and it idles fine and dandy, but now, when i hit the throttle it just sucks in air really hard through the top hole in the tb, thats iacv right? well ive already cleaned it and tested it and the actuator thing inside works. so now, what do i need to try. ive had this problem before but cant remember how i fixed it. oh, and no codes...
top hole in the throttle body? there is a larger opening for the hose that goes to the charcoal canister and then a smaller vacuum line which goes to your map sensor. assuming your still running an obd0 tb with a firewall mounted map.
yeah i know, but when i hit the throttle it bogs hard and sucks air loudly and will die unless i let off, it will rev up to rev limit if i do it really slow.
Turb0wned
38
Jun 13, 2010 09:50 AM
asubennett
Sep 30, 2003 03:19 PM
