D16Z6 Swap
Hey guys , does anyone kno what dizzys you can use on the d16z6? i herd the d15b7 one will work but i wanted to confirm that. also could i use my Tranny+starter from my d15b2 on the d16z6 block/flywheel?
If you have done the swap and added the wires for the MPFI and VTEC can you let me kno how that went? is it easy or is it a confuseing mess?
Thanks
Thanks
not sure if you can use the d15 one.. but why not get the right distributor? The starter and trans will work fine. And ive done a mpfi swap and vtec wiring, but i couldnt tell you how hard it is. depends on your electrical knowledge.
