Energy suspension bushings.
I am trying to replace my bushings on my Blox LCA's, just have a quick question. I am only replacing the Rear Shock Mount Bushings, and need to know if it will fit right in since they are not stock LCA's. I called EnergySuspension and they told me the stock ones are 37mm (shock mount that is) and to cal Blox to see if it is the same size. no answer from Blox still waiting on an emial.
^ If I would of known these bushings go bad quick and there isnt a bolt pattern for the stock gsr sway bar, I would of kept the stock ones with new bushings.
After some research..looks like it will be a perfect fit.
Inner Bushing: EG/DC
Width: 50mm
Diameter: 37mm
Also the link, if anyone is in the same situation I am in.
http://www.energysuspensionparts.com/proddetail.asp?prod=16.8103
Width: 50mm
Diameter: 37mm
