Air Conditioning w/ Mugen Intake?
Old Aug 18, 2009 | 08:39 AM
iheartintegras's Avatar
Default Air Conditioning w/ Mugen Intake?
Was thinking about installing my AC. I think I've read somewhere that you can make it fit with the intake if you bend the lines. Does anyone currently have the Mugen intake w/ ac installed?
Old Aug 18, 2009 | 09:17 AM
get RIGHT's Avatar
Default Re: Air Conditioning w/ Mugen Intake?
When you get the hard AC lines back in just gently bend them out of the way. Its not hard just be gentle.
Old Aug 18, 2009 | 09:19 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
I know with the version 2 Mugen intake, it's a tough fit. We tried installing it on my friends car and there was no way it was going to fit without some serious bending of the a/c lines. He decided not to use it.
Old Aug 18, 2009 | 09:48 AM
itr1236's Avatar
I had the Mugen intake on both my 00 and 98 ITR. It can definitely work, and you do have to be gentle with the lines. It worked out a lot better on the 2000 simply because I only installed it once. On the 98, some other people worked on the car other than myself, plus the intake went in and out of the car on multiple occasions. With those two things, there was a lot of pressure put on one of the AC lines and it eventually developed a kink which meant not so good AC.
If I were to do it again, I would try to figure out a way to do it with custom AC lines, but that's just me...
Again, it can work just fine with the stock lines.
I'm thinking about buying your car too... So I'm all about installing the AC!
Old Aug 18, 2009 | 09:51 AM
wannabe_itr's Avatar
does anyone have a pic
Old Aug 18, 2009 | 01:04 PM
tipe R's Avatar
sort of off topic. i was suppoed to get my mugen intake this month but just found out out it's back ordered from mugen japan--bummed
it would be nice if someone could post pics cause my 2000 has A/C
Old Aug 18, 2009 | 01:23 PM
get RIGHT's Avatar
After 30 seconds of searching. Here is with and without.
Old Aug 18, 2009 | 01:44 PM
wrinkly's Avatar
i just finished the mugen intake on my 97 ITR half an hour ago..and yea you definitely have to bend the ac lines to make it fit. in fact, for me i had to take the entire transmission brace off to be able to get he darn snorkel in.
on a side note, i notice that i have a higher idle now that i have installed the intake..its hovering around 1k rpm and will only drop when i fully depress the clutch and release when in neutral
sorry to thread jack but anyone have any ideas?
Old Aug 18, 2009 | 07:59 PM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
kinda off topic too but is there a difference in power from maybe a aem cold air intake to the mugen intake?? other then well price wise
Old Aug 18, 2009 | 09:32 PM
soulassassin13's Avatar
I installed the Mugen intake with A/C. It took a while to fit it, but it was well worth it.
Old Aug 19, 2009 | 02:17 AM
nautica_t's Avatar
shiet you guys are lucky!!!
a/c was optional in canada. i don't have ac in my 01R..
trying to find a used complete kit, is a biatch.
Old Aug 19, 2009 | 06:35 AM
get RIGHT's Avatar
Check the FAQ thread. This is the best dyno proven intake for an NA ITR on the market. Well worth every penny.
Old Aug 19, 2009 | 07:17 AM
Little_Nolan's Avatar
OP: Remove the hard line bracket infront of the tranny mount, move the lines gently apart and squeeze it in there. The AC line parts that were questionable or did rub can be covered in rubber hosing to keep from destroying them or the intake.
This is how it was done on my brother 97' R with oem AC
Old Aug 20, 2009 | 07:10 AM
tipe R's Avatar
Is there much of a gain with this intake? I was under the impression that it was designed for response.
Old Aug 20, 2009 | 10:58 AM
Yes this intake has dyno proven power gains over almost every other intake
c0l7hy
Aug 21, 2005 04:58 AM
RhdRicheeee
Feb 26, 2005 10:42 PM
Chris93Si
Sep 20, 2004 11:11 AM
George H
Apr 22, 2003 08:12 PM
White Dragon
Nov 20, 2001 07:46 PM
