90 civic hatch LS turbo BEST OFFER!!
I have a 90 civic hatch. Needs passenger side body work and some bigger tires lol. I would like to get rid of it asap, found something bigger and better. Make a reasonable offer on it and we can talk. It has the following mods done to it:
B18a1 bottom end with a B18b1 Head
GSR YS1 Transmission with a 6 puck SPRUNG clutch and Fidanza 8lb flywheel
DA Front lip for the rear bumper (needs to be insalled)
Amber corners
MK3 VR6 front lip (needs to be be installed)
OEM Carbon fiber hood (havent put it on yet)
Chipped PR4 with a tuned basemap. Can up the boost with bigger map sensor. Currently running 8lbs
Battery relocated to the back
Wire tuck to the max
Hasport mounts
Hasport Shifter linkage
Skunk 2 Dual Bend shifter
Energy Suspension Shifter bushings
Ramhorn manifold, 38mm wastegate 10 psi spring, 54 trim turbo, with open downpipe
Civic radiator and fan on gangsta lean wired to a switch
Thick *** intercooler
TurboXS RFL BOV
T bolt clamps and 90 deg coupler from Verocious
Oil pan tapped and custom line made by Verocious
Sitting on Tokico blues, with adjustable coilovers on the front and stock in the rear. I didn't want to break the bolts but I have the tokicos for the rear.
The bad: It would be faster with something bigger than a POS 13 in wheel. I put some Radials on it just for ***** and giggles and kept up with a 12 sec car. So it needs some bigger tires. Would recommend a traction bar kit to help with wheel spin. The passanger side quarter panel will need to be pulled or replaced. This doesn't affect the way the car drives though. Speedo doesn't work due to the cable being broken, so just slap a new one on and that fixes it. It is kind of loud but when steady cruising its not bad. The driver side seat is torn up, but what do you expect from a old *** car lol. There isn't a radio (didn't come with one). Other than that its a pretty quick little car that I've had my fun with but Im getting rid of it.
2000 takes it home.
Needs a good cleaning!!
I will include the trim piece that goes between the hood and bumper.
The ugly damage. The quarter panel might be able to be fixed but I think it would be better to throw another one on there. Also I have a set of EK sideskirts to cover up the dented bottom side under the door.
302-419-7363
Amber corners
Hasport mounts
TurboXS RFL BOV
2000 takes it home.
302-419-7363
drumritter258
Mid-Atlantic (Sales)
21
Sep 25, 2009 09:15 AM
