FS: FULLY BUILT BLOCK, LIBERTY TRANS, MSD DIG 7, TURBO KIT, S300, SHELL W/CAGE&CHUTE
Motor is as follows: $4800+shipping!!!! Will Come with everything listed below.
LS block
GE Sleeves w/Orings
CP 84mm pistons with upgrades wrist pins (flat tops 10:1 cp)
Manley rods (LS)
LS crank
Clevite Bearings
OEM Oil/Water pump
LS oil pan Tapped
GE LS/Vtec Kit
GE 84mm head gasket
GSR Head
Fully Ported and Polished by Ryan@Warr heads
GSR Cams
Supertech Springs/Retainers
Supertech Inconel Exhaust valves
Bronze guides
Valve Job
High Amp Alternator
Wiring Harness included
3 Distributors wired for the external coil, 1 LS, 2 GSR's
Edelbrock Intake Manifold (intake port matched)
Stock GSR throttle body
Starter
**Mounts/Trans/Scatter Shield/Breather Kit/Fluidamper NOT Included!**
Garrett 4294 Journal Bearing $750 Shipped!
Includes Gasket, Feed/Return lines and fittings.
4" Down Pipe w/flex $300 shipped
VERY well constructed to fit RIGHT up against the slave cylinder and oil pan for a tight
fit to help keep room for traction bar & engine catch pan.
[IMG]http://i52.photobucket.com/albums/g36/BLKTeg-94/22.jpg[/IMG
DriveTrain:
Liberty Dog Box transmission with Quaife (GSR ratios, B16 Quaife) $4300 SHIPPED!
Exedy Twin disc Clutch $1050 SHIPPED!
Has Ten Passes on it and approx 200 miles total!
Avid Traction bars $300 SHIPPED!
IN NEW condition!
PLX Wideband w/bosch sensor $210 Shipped
AEM Boost solenoid $75 shipped
MSD Digital 7 Plus Prog (#75314 4 cyl apps only) $730 shipped
PRETTY MUCH BRAND NEW!!! Only used for 3 passes and 15 dyno pulls.
Will include Serial Cable with IOGear USB adapter cable.
And Wiring Harness if wanted, Shielded Air Craft Wiring was used and need to be grounded.
Shielded wiring reduces electric interference from the box and ECU.
MSD Dig 7 HVC II Coil $160 shipped
IN BRAND NEW CONDITION! Used for 3 passes and 15 dyno pulls!
Aeromotive Eliminator Pump $350 shipped
Dual summit filters with 100 michron inserts (before and after the pump) $100 for both
Golden Eagle Fuel Rail $100 shipped
with -10an & -6an fittings
Hasport Solid Mounts Powder coated black $300 shipped - Pending
Del Sol Dual Core Radiator w/slim fan $110 shipped
Full Racing Suit $350 shipped
Shroud Pants - SFI Cert 3-2A/5 - Large
Shroud Jacket - Double lined SFI Cert 3-2A/5 - Large
Simpson Shoes - Size 12
Shroud Gloves - SFI Spec 3.3/1 - Medium
Shroud Neck Brace - SFI Spec 3.3
VIS Invader Carbon Fiber Hood $350
1994 Acura Integra GSR Black Chassis: $3500!!! Local pickup only!
10 pt Cage, not cert yet but built for certification to 8.50's
Custom fitted MR Window net
Certified shroud 5 pt Harnesses (both drivers and passenger)
Shroud Parachute
Innes Cutoff Switch
Rolling on stock struts/springs
OMNI Camber Kit (front)
Powder coated wheel with Toyo Rears, Falkin Front tires
No fuel system!
Paypal address is SupraTT_T78@hotmail.com
Jason
801-879-4940.
I do have texting so. Text me if ya got questions.
LS block
GE Sleeves w/Orings
Manley rods (LS)
LS crank
Clevite Bearings
OEM Oil/Water pump
LS oil pan Tapped
GE LS/Vtec Kit
GE 84mm head gasket
GSR Head
GSR Cams
Bronze guides
Valve Job
High Amp Alternator
Starter
DriveTrain:
IN NEW condition!
Shroud Parachute
Innes Cutoff Switch
No fuel system!
Jason
801-879-4940.
Last edited by BLKTeg94; Sep 1, 2009 at 07:43 PM. Reason: Updated pics and prices!
She made 773hp@30 PSI. Due to small drums it wouldn't load anymore to make more boost.
Best track time was only 10.006@148. best mph was 149mph. Ever since I put the dig 7 in and re-dyno'd I haven't be able to get a clean hit out of her.
http://www.youtube.com/watch?v=z-Wsp41edxg
