(Supid Question) Whats tread wear???
Old Aug 25, 2002 | 07:32 PM
EVIL Hx Coupe's Avatar
Default (Supid Question) Whats tread wear???
Like the topic says, and is higher or lower better????
Old Aug 25, 2002 | 08:21 PM
the DR.'s Avatar
Default Re: (Supid Question) Whats tread wear??? (Boost Pressure)
treadwear rating on tires = how long they take to wear, 100 was the benchmark a long time ago so thats used as the supposed average. the higher the number the longer the tire is supposed to last, say treadwear rating of 400 will last 4 times longer than the "average" some tires go way beyond 400, lower numbers usually dont last quite as long but they do have better grip, most r-compound tires are under 100 treadwear rating, i think falken azenis is a little over 100 also so in turn they'll grip well
Old Aug 25, 2002 | 08:58 PM
FifthGearOnline's Avatar
Default Re: (Supid Question) Whats tread wear??? (CIVICtypeS)
heres some info from discount tire
Uniform Tire Quality Grading System
The US Government has established the UTQGS, the Uniform Tire Quality Grading System, to assist consumers in their purchase of tires. Basically it's another tool to be used besides the opinions you gather from trusted friends, mechanics and whatever other sources you may have at your disposal. The key to using this system is to understand that it is a relative comparison system. The UTQGS is not a safety rating and not a guarantee that a tire will last for a prescribed number of miles. Under UTQGS, tires are graded by manufacturers in three areas: treadwear, traction and temperature. The information is right where you need it when buying the tire 1) on the paper label affixed to the tread and 2) on the tire molded into the sidewall.
Treadwear
The treadwear grade is a comparative rating based on the wear of a tire when tested carefully under controlled conditions. For example, a tire graded 400 should have its useful tread last twice as long as a tire graded 200. Another tire manufacturer, however, may grade a comparable design 300, so a grade of 150 would last just half as long under their grading scheme. The lesson learned is to not use one manufacturer's grade versus the other, but instead to compare tire grades within a given brand. Actual treadwear performance can vary tremendously according to the tire's real-world use: variations in driving habits, service practices (most importantly air pressure maintenance) and road conditions and climate affect tire life.
Traction
Traction grades represent the tire's ability to stop on wet pavement as measured under controlled conditions on asphalt and concrete test services. As of 1997, the traction grades from highest to lowest are "AA","A","B" and "C". A tire graded "AA" may have relatively better traction performance than a tire graded lower, based on straight-ahead braking tests. The grades do not take into consideration the cornering or turning performance of a tire.
Temperature Resistance
Temperature grades represent a tire's resistance to heat and its ability to dissipate heat when tested under controlled laboratory test conditions. The grades from highest to lowest are "A","B" and "C". The grade "C" corresponds to the minimum performance required by federal safety standard. Thus the "A" tire is the coolest running, and even though the "C" tire runs hotter it does not mean it is unsafe. The temperature grade is established for a tire that is properly inflated and not overloaded.
[Modified by FifthGearOnline.com, 11:58 PM 8/25/2002]
Old Aug 25, 2002 | 10:31 PM
BlackDeuceCoupe's Avatar
HT White Ops
Higher lasts longer. Lower performs better.
Old Aug 26, 2002 | 05:43 AM
Default Re: (Supid Question) Whats tread wear??? (BlackDeuceCoupe)
Thanks alot guys.
kornerk12
Feb 25, 2009 03:10 PM
tackyjan
Honda Civic (2006 - 2015)
Feb 28, 2008 07:18 AM
nsxtasy
Mar 1, 2006 09:30 AM
98AcuraGS
Sep 14, 2002 07:06 PM
Kengs
Nov 7, 2001 01:51 PM
