ef b series shift linkage
Might pick up an ef with ls swap on blades for 1250, has no header/cat or shift linkage. Saw he had custom shift linkage, is this necessary or can i use an integra (da,dc) or em1 shift linkage? I'll be searching and will delete this if i find my answer first, thought i'd post up cause its a spur of the moment deal
hasport doesn't make the linkage any more. its made by innovative now. but, you can ue da shift linkage. but, you have to have it cut and welded. something like an inch or something, or a little more than an inch. not sure, but its not much i know that. lol.
you need to cut 2 3/8 off of it its super simple just make sure you draw some lines on it before you cut it up so they will line up right oh and also cut on the straight portions of the linkages i bent mine a bit so it didnt hang as low as it did something to look at it shifts great for me
hatch_kidb18b1
May 6, 2009 06:39 PM
