jdm B16a with 12:1 compression. bigger injectors???
Old Aug 17, 2009 | 07:55 PM
dansnyder22's Avatar
Default jdm B16a with 12:1 compression. bigger injectors???
OK, so this is my first post but I have used the search feature on this forum for years and I really appreciate how helpful everybody is.
for this question I have searched the entire site and cannot find a proper answer.
I am building a JDM B16A with 12.0:1 compression pistons stock compression is around 9.4:1 I believe. I am aware that I will have to use high octane fuel. But will I have to use bigger injectors? if so, how big?
thank you for your help
Old Aug 18, 2009 | 05:22 AM
goforbroke's Avatar
MEAT PATTY
Default Re: jdm B16a with 12:1 compression. bigger injectors???
What does your build consist of? Your stock injectors will be fine up to 200-210whp depending on fuel pressure. Your tuner should be able to show you the duty cycle of your injectors on the dyno when he's tunning it. With a good tune you can run 12:1 compression on the street provided your running 93-94 octane(east coast). You compression probably isn't even that high though.
Spend your money else were with your build.
Old Aug 18, 2009 | 08:44 AM
TorquelessEM1's Avatar
Just so you know the stock comp ratio is 10.4 to 1
Old Aug 18, 2009 | 11:13 AM
i am doing a full rebuild with new pistons, valves, water pump, oil pump, bearings and seals.
do high compression pistons require better connecting rods???
Old Aug 18, 2009 | 02:02 PM
88Hatchy's Avatar
your stock connecting rods will be fine.
Old Aug 18, 2009 | 06:57 PM
Top Ramen's Avatar
If you have an idea of what kind of hp your build will make, you can calculate whether your injectors will be sufficient at an 80% duty cycle (good limit).
What are you tuning with? Most good systems can idle fine with big injectors, so I generally play it safe and get a bit bigger than I will probably need.
Old Aug 18, 2009 | 07:28 PM
anothersickhatch's Avatar
your stock injectors should be fine.
1998GsRIntegra
45
Nov 3, 2010 08:00 PM
DC2 Mang
Jan 26, 2006 02:52 PM
doublejz
Aug 10, 2005 03:41 PM
SIReg9
Feb 17, 2003 07:55 PM
JediPimpCrx
Sep 17, 2002 07:09 AM
