BIGGEST EG PARTS LIST TONS Ex/Del Sol
This is just some of what I have its quite the list.. But there are Del sol parts and Civic EX coupe parts..
As follows off my 1994 honda civic ex coupe
Power window door panels GREY
Full oem intake
Full AC lines
Outer left taillight
Outer right taillight
EG coupe hood cowl
14" honda/acura steelies no tires (2)
1986 Vintage 13" prelude spider web rims tough to find full set
92-95 coupe Front crash beam
D16z6 fuel rail
D16z6 Fuel injectors (4)
D16z6 power steering pump and belt
D16z6 VTEC valve cover
D16z6 power steering pump bracket
14" oem Ex hubcaps (4)
92-95 AC condensor and fan
92-95 civic coupe oem sideskirts
92-95 civic rear sway bar
92-95 civic wiper arms
d16z6 DIZZY
2 honda civic eg horn relays
EG8 JDM airbox
92-95 cruise control unit under hood
1994 honda civic manual
92-95 honda civic P/S outer black door handle
92-95 honda civic rear speaker panels
Honda civic main relay RZ-0159
D16z6 fuel pressure regulator
Hazard Relay
Resume/SET/decel cruise switches for steering wheel
92-95 civic p/s teal green outer door handle
92-95 civic power mirror relay switch
92-95 civic sunroof relays
92-95 civic JDM power folding mirror switch with pigtail
92-95 coupe rear ashtray GREY
92-95 civic defrost switch
92-95 civic cruise/sunroof/dimmer switch
Resume/Decel switch
92-95 civic P/s front door latch
92-95 civic steering column
92-95 civic ex under dash ac/heater wiring harness
92-95 civic oem battery tray and tie downs
92-95 civic front speaker covers BLACK
92-95 P/s Manual window regulator
92-95 Grey lower steering column cover
92-95 interlock control assembly relay
92-95 honda civic horn
92-95 civic grey ebrake
92-95 honda ciic grey front speaker covers
92-95 honda civic ex brake booster
92-95 honda civic brake master cylinder
D16z6 upper timing belt cover
(5) under dash fuse boxes.... 2 are for passenger airbags
D series upper thermostat hose
92-95 Auto/Brake pedals
92-95 civic D/s window regulator power
92-95 civic p/s window regulator power
92-95 honda civic d/s door latches EX
92-95 civic p/s door latch EX
d16z6 obd1 alternator
92-95 civic ex front lower control arm D/s
92-95 civic ex front lower control arm p/s
92-95 civic EX oem full suspension
d16z6 D/s mount
d16z6 p/s mount
d16z6 D/s axle
d16z6 p/s axle
92-95 civic ex P/s airbag grey
92-95 civic ex p/s rear lower control arm
92-95 civic ex front brake calipers
92-95 civic d/s front knuckle
92-95 civic p/s front knuckle
92-95 civic ex airbag harness
92-95 civic ex airbag module
92-95 civic ex hood latch cable
92-95 civic ex rear view mirror
92-95 civic gas lid cable
92-95 civic windshield washer hoses for hood
92-95 civic ex trunk latch
92-95 civic trunk molding
92-95 honda civic coupe cruise control cable
92-95 civic coupe rear speaker panels
92-95 civic ex throttle cable
92-95 civic ex auto shifter
92-95 civic thermostat hose
92-95 civic front seat belt grey d/s
92-95 civic front seat belt grey p/s small tear
92-95 honda civic interior wiring harness
92-95 honda civic firewall harness
(3) honda windshield washer bottles
92-95 civic ex fuel pump
92-95 civic ex gas tank
92-95 coupe rear seats grey
NEW spare tire oem
92-95 civic over flow radiator bottle
92-95 civic firewall foam
92-95 civic ex ac compressor bracket
92-95 windshield wiper regulator motor
full spare tire set with compartment
92-95 civic ex auto ignition with key
92-95 rear window carpet with speakers
92-95 civic ex apillars grey
92-95 civic ex p/s inner door molding
92-95 civic ex p/s outer door molding
92-95 civic ex d/s inner door molding
92-95 civic ex d/s outer door molding
92-95 civic ex d/s window molding
92-95 civic ex p/s window molding
92-95 inner door grey molding in frame
92-95 civic ex lower steering column cover
92-95 civic ex rear quarter panel liners
92-95 civic coupe hood molding
92-95 civic ex d/s door hinges
92-95 civc ex p/s door hinges
92-95 civic inner door handle p/s
2 oem full sets of lugnuts for 88-00 civics
92-95 civic front grey seats
92-95 floor board speaker panels for front
92-95 civic ex outer moldings for car
92-95 civic ex d/s outer door handle
92-95 civic ex p/s outer door handle
92-95 civic rear trunk lock
92-95 civic ex rear trunk latch
92-95 civic full trunk carpeting
92-95 civic coupe front grey carpeting
92-95 civic ex coupe full taillight set
92-95 civic coupe rear plate garnish
92-95 civic ebrake console grey
92-95 civic trunk emblem
92-95 civic foot rests (3)
92-95 civic gas lid purple
92-95 civic coupe d/s rear seat belt
92-95 civic coupe p/s rear seat belt
92-95 civic console with cupholder
92-95 civic radiator fan
92-95 civic coupe grey rear interior panels
92-95 civic ex coupe dash grey
92-95 civic coupe headliner
92-95 civic d/s fender coupe
92-95 civic p/s fender coupe
92-95 civic b pillars
92-95 civic trunk purple
92-95 civic coupe d/s door purple
92-95 civic coupe p/s door purple
92-95 civic coupe passenger window
92-95 civic coupe rear bumper
92-95 civic coupe rear bumper foam
92-95 civic ex tweeters
92-95 ex p/s window switch grey
92-95 civic d16z6 vtec solenoid
92-95 civic rear crash beam
92-95 civic hood purple.. little bubbles forming
92-95 civic hood hinges
92-95 civic hood latch
and now for the del sol list as follows:
93-97 del sol front crash beam
93-97 del sol rear crash beam (2)
del sol altezza taillights one small hole in it
del sol windshield side moldings
del sol oem sideskirts
del sol gauge cluster harness
del sol tailight harnesses
del sol trunk molding
engine harness for d16z6 tapped
under hood cruise control with cable
del sol wiper arms
del sol under hood fuse box
del sol tarmac latch assemblys
d/s front knuckle newer bearings
p/s front knuckle newer bearings
hood latch
p/s small window molding
tarmac roof moldings for side with screws
windshield moldings
del sol seats with red stripe
gas release lever
tarmac roof latches
del sol rear view mirror
ebrake handle
gas lid black
under hood a/c wiring harness
del sol carpeting (2)
del sol rear trunk carpeting (2)
del sol black glove box
p/s window
del sol p/s outer door handle BLACK
ac evaporator
d/s door handle inner for panel
p/s door handle inner for panel
p/s power mirror.. small crack on mirror
a/c harness cabin
d/s power window harness non power mirror
d/d power window harness with power mirror
88-91 CRX battery cables
88-91 crx lugnuts (7)
d/s front lower control arm del sol
d/s red zigzag oem floormat
93-97 main tarmac roof molding front and rear
rear window molding
gauge cluster 135,179 miles
ac/interior harness
hood cable
hood release
p/s belt buckle
hood latch
front speaker panels
rear speaker brackets
a/c climate control harness (2)
p/s power window/mirror harness
del sol dash non airbag
del sol dash with airbag slot
del sol front suspension
del sol rear interior panels.. every piece i have
del sol rear window
rear window regulator
rear storage compartment
p/s door red
del sol door sils
seat belt panels
p/s seat belt
aux lt/cruise switch
hazard/defrost switch
console for the switches
del sol AC lines
tarmac roof trunk latch
Lots more to come but i thought that was a good start.. pm me offers.. need all this gone.. have pics for all.. send me emails for pics..
Thanks
Full oem intake
Full AC lines
EG coupe hood cowl
D16z6 fuel rail
d16z6 DIZZY
EG8 JDM airbox
Hazard Relay
Resume/Decel switch
d16z6 D/s mount
d16z6 p/s mount
d16z6 D/s axle
d16z6 p/s axle
NEW spare tire oem
del sol wiper arms
hood latch
windshield moldings
gas release lever
tarmac roof latches
ebrake handle
gas lid black
p/s window
ac evaporator
a/c harness cabin
rear window molding
ac/interior harness
hood cable
hood release
p/s belt buckle
hood latch
del sol rear window
p/s door red
del sol door sils
seat belt panels
p/s seat belt
del sol AC lines
Thanks
hi, both eg fenders
and hood release cable shipped to 77904
also do u have mud flaps f/r for eg?
thanx.
thanx.
