Solution for Slow Power Windows
Old Aug 25, 2002 | 07:02 PM
cd555's Avatar
Default Solution for Slow Power Windows
The reason the windows are slow is because the rubber weatherstripping that the window rides up in is dried out. Its easy to tell because a new "rubber" will be black and the old one will be a dark grey and really dry. If not changed it could cause the power window motors to burn out. Its expensive but worth it, its like 74 after tax from Honda. My rear windows are fine, but I had to replace the front two. Its easy to replace the stripping too, its just a bit hard to align it up for proper placement.
I hope this helps
Old Aug 26, 2002 | 04:57 AM
greensleeper's Avatar
Default Re: Solution for Slow Power Windows (farroutt)
I replaced that ****. no improvement. its just a shitty design to start with. honda has admitted it.
Old Aug 26, 2002 | 05:35 AM
WuWarrior's Avatar
Default Re: Solution for Slow Power Windows (greensleeper)
yea, my car was garaged for a few years. my passenger side window moves VERY slow. I sprayed some silicone lubricant on the side and it did improve a little bit.
Old Aug 26, 2002 | 06:53 AM
H23 Power's Avatar
Default Re: Solution for Slow Power Windows (WuWarrior)
push it
Old Aug 28, 2002 | 09:38 AM
forcedaccord95's Avatar
Default Re: Solution for Slow Power Windows (F23 Power)
Armoral is the cheapest fix, my windows work like new
Old Aug 30, 2002 | 05:11 PM
TypeSH's Avatar
Default Re: Solution for Slow Power Windows (forcedaccord95)
any chance a more powerful window motor would help? any easily swapable power window motors?
Old Aug 30, 2002 | 07:02 PM
XMarkGuerillaX's Avatar
its always the passenger window mine is AFU to..
Old Aug 31, 2002 | 06:08 AM
Gennady's Avatar
New User
This is like having the smallpox vaccine and not using it.
Old Aug 31, 2002 | 07:16 AM
UseR's Avatar
Funny i have that problem too, but no need to go to honda and get overcharged. Im curious about these sprays and if they are really effective. My two front windows are also SLOWER than the back two. I mean which one out of all the sprays that you all have mentioned the best for this situation?
Old Aug 31, 2002 | 07:35 AM
Gennady's Avatar
New User
Default Re: Solution for Slow Power Windows (Wont be beat)
I give up.
Old Aug 31, 2002 | 03:35 PM
Cryogen97's Avatar
I've used the silicone spray with good results. It's good for the rubber too.
wizarddrummer
Sep 4, 2012 10:44 AM
jdm_jeners
Sep 8, 2006 07:59 PM
professorman
Nov 17, 2004 10:54 AM
137
20
Feb 17, 2003 08:15 AM
