She wont start. 91 CRX Si
I have a 91 CRX Si, turbo zc low boost. A couple days ago i had left the radio on over night and when i went to start the car in the morning the battery was completely dead with next to NO GAS in the car. I tried jumping the car about 3 times (5-10 minutes everytime) and it did absolutely nothing. No radio no lights no nothing so i tried bump starting it countless times and nothing, itd start puttin but not enough gas to get her going. So i decided to buy a new battery today since it wasnt holding a charge, i replaced the battery and still, NOTHING! No radio no click no nothing. Im running out of money and i need to fix this problem before friday when i start work, im thinking it could be the alternator but i just dont know. The car has been properly converted to obd1 aswell.
Anything will help, Please. and Thank you
When i replaced the battery this morning, i know it was fresh cause the alarm was loud as ****. All the normal lights come on when i go to start it, but it just wont start. if you have any suggestions it would be greatly appreciated.
If your getting power, and its not starting. You might not be getting a spark, check the plugs, fuel pump, injectors, starter could be anything but im not a genius
hmm, did i add gas? thats a good idea. i got bout a half tank left
thanks for the tips about the fuses. i got a guy thats an electrician and he'll hook me up. gonna try tomorrow and hope for the best. thanks ya'll
Is your car a manual? If it is check the clutch interlock switch at the top of the clutch pedal. They have a rubber stop that engages the switch and over the years they rot and fall off.
it sounds like you got a bad battery cable. Try tugging on the ground cable while someone is turning the ignition. if that doesnt do it then try the same with the positive cable.. then let us kno how that works
I was going to say either the Battery fuse under the hood might be blown if you are getting no lights or anything. I would also check the ignition switch if the battery terminals/fuse is still good.
hey its relly a matter of thinking.if you have changed the battery it should have worked. if it is not working there must be a problem with the radio section.
stoney13142000
Dec 9, 2011 12:05 PM
SOKDO
Jun 2, 2005 10:33 AM
