oem car cover -- good for outdoors?
Just as the title says, i am curious if the OEM car cover is made specifically for indoor use only? It seems more like a blanket that would soak then the cheap aftermarket cover i had for my civic.
i wouldnt use it outdoors by itself. if you want, use that on your car, then get an outdoor car cover to put on top. or you could just get a high quality outdoor car cover that has a soft interior and a durable exterior
I use mine outdoors 24/7. It used when I park at work and at my living complex.
I live In SoCal and it was the best thing i have purchased for the S. Of course i would not use it for bad weather. It is used to prevent dust getting on the car and also shades the car from the sun. I never wash the car, I use detail spray once a week to keep it clean.
i use a covercraft noah one for the outdoors that includes a lot of rain + snow.
i also use a wolf noah for my integra. same material.
the covercraft one is better for the S2K because it comes w/ a little pocket for the antenna as well.
I honestly would never use a car cover outside, unless it is for a very short period of time. Had a car cover on a vehicle parked outside, when the wind blew, dirt would collect inside the cover. When I pulled it off a week later, I could have replicated the same results with some 600 grit sandpaper.
i've had my s2k out in the winter for 5 months and my teg covered for 7 months total now and don't have any problems you're describing.
about $200
http://cgi.ebay.com/ebaymotors/COVER...Q5fAccessories
the Wolf brand cover with the Noah material will be cheaper, but you will need to unscrew your antenna if you get that one
I found some decent ones from empire. This cover was a replacement cover for a custom cover that cost three times as much and started leaking water and collecting dust under the cover in less than a year. My Empire cover is 4 months old, has survived numerous strong thunderstorms and seering Texas sun, and so far is exceeding my expectations. I have 3 cars under cover, soon the other two will be covered by Empire.
http://empirecovers-review.blogspot.com/
no. OEM cover is a DUST cover and will fail to the elements. You are going to need to step it up and get a good cover. Usually will run you about 240+ depending. Google is your friend.
Gottaprblm
Honda Civic (2006 - 2015)
16
Apr 13, 2006 04:45 AM
