Is this a clutch cable problem or something else
Old Aug 25, 2002 | 06:30 PM
NixTEG's Avatar
Default Is this a clutch cable problem or something else
I was exiting off the hiway when i noticed there was hardly any travel in the clutch pedal , then i couldn't swich gears or anything .
I pulled over and checked the clutch cable and noticed it was really loose and it had no tension !!
So i tighened the plastic nut on the cable on the plastic threads about an inch and a half before there was tension on the cable again , then it was shifting with no problem again but the pedal was releasing at the top !!
Is this a cable problem or something else ?? Just wanted to know before i replaced the cable !!
And the clutch DOESNT SLIP !! so i dont think its the clutch !!
setup is : B18B motor with a b16 tranny and type R clutch and PP with a 12 lb GSR lightened flywheel in a 90 teg RS !!
kid_02131
12
Nov 6, 2013 05:32 AM
DAmn
Jul 21, 2005 10:27 PM
NixTEG
Aug 25, 2002 07:57 PM
