pin code confusion
ok guys after a lil while of me not postin im bak again lol. ive run into a problem wit my rex. As some of u may remember i was in the process of swapping my 88 dx to a full 90 Si. we for the most part it is completely done with one acception... when i picked up the full swap i didnt realize that the dash harness was missin. So now everything works with the exception on my fuel tach and coolant gauge.
ok so to the point my question is this...
Does neone kno which 3 wires from the 88 dx dash harness is for the fuel, coolant and tach? and which are the same from the plugin on the 90 si ?
Here you go:
For all information reguarding cluster swaps. http://www.geocities.com/speed_phrea...ow2cluster.htm
No Problem, just as a hint for searching for things, go to google and type like "insert question here" site:honda-tech.com
This shows only results on honda-tech.com, makes things alot easier.
EG6_LS_BOOST
Feb 13, 2013 05:32 AM
RA122324
Jun 28, 2005 03:06 AM
