Transmission & Drivetrain Gearboxes, Differentials, Clutches
Keep breaking 3rd gear shift fork
Old Aug 17, 2009 | 10:30 AM
onereving7's Avatar
Default Keep breaking 3rd gear shift fork
I have a d16y7 with a ex B000 transmission. So far it has broke about 3 or 4 shift forks. What could be causing this? the clutch is a newer (maybe 10k mile) action 2ms set. Im not sure it if is a clutch disengagment problem or what. Any ideas??
Old Aug 17, 2009 | 07:15 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Keep breaking 3rd gear shift fork
I've never seen a 96-00 steel shift fork break.
Did you correct the factory issue with the 3-4 slider?
Old Aug 17, 2009 | 07:19 PM
kaiba's Avatar
Wow. Either you need to learn how to shift or you just have bad luck.
Old Aug 17, 2009 | 07:21 PM
kaiba's Avatar
What happen right before it broke? Shifting into gear aggressively???
Same clutch on all broken tranny??? OEM style, 6 puck, 4 puck, 3 puck????
Need more info.
Old Aug 18, 2009 | 06:24 AM
onereving7's Avatar
Yes there was agressive shifting, same clutch on all the transmissions. I broke 2 forks on one transmission, then replaced the complete unit for another which just broke.
Its a 6 puck sprung clutch.
Im not sure if the transmissions are 96-00, they might be 92-95
Old Aug 18, 2009 | 07:09 PM
Mista Bone's Avatar
D Tranny Guru
Driving needs modification
Old Aug 19, 2009 | 08:45 AM
onereving7's Avatar
ive owned the car for about 6 years. No problems until i put this action 2ms clutch in it. Can it be any way related to that? if not , i will take the driver mod into consideration but i need some other ideas.
Thanks for the help. im tired of getting these things replaced. how easy is it to do on my own?
Old Aug 19, 2009 | 09:17 AM
kaiba's Avatar
I'm gonna said that clutch is too aggressive for a stock D tranny.
Does your clutch look something like this.
And if so. Why do you need a clutch like that? It's only a D16Y7.... turbo, stock????
Old Aug 19, 2009 | 08:41 PM
onereving7's Avatar
its turbo, makes a little over 300. One transmission had a quaife lsd and syncrotech syncros, but i know that doesnt help the shift forks. And yes the clutch is close to that
Old Aug 20, 2009 | 01:04 AM
Ramma's Avatar
Do you rest your hand on the shifter when in gear? The added stress can cause shift forks to break. Just an idea.
lokodog
Dec 25, 2005 09:39 PM
japhonda
13
Jul 30, 2005 01:19 PM
TJ95CivicEG
10
Jul 24, 2005 04:03 AM
gsr camel
Nov 17, 2001 08:18 PM
