Is this a clutch cable problem or something else ??
Old Aug 25, 2002 | 06:23 PM
NixTEG's Avatar
Default Is this a clutch cable problem or something else ??
I was exiting off the hiway when i noticed there was hardly any travel in the clutch pedal , then i couldn't swich gears or anything .
I pulled over and checked the clutch cable and noticed it was really loose and it had no tension !! So i tighened the plastic nut on the cable on the plastic threads about an inch and a half before there was tension on the cable again , then it was shifting with no problem again but the pedal was releasing at the top !!
Is this a cable problem or something else ?? Just wanted to know before i replaced the cable !!
And the clutch DOESNT SLIP !! so i dont think its the clutch !!
setup is : B18B motor with a b16 tranny and type R clutch and PP with a 12 lb GSR lightened flywheel in a 90 teg RS !!
[Modified by SlowCivicNick, 3:25 AM 8/26/2002]
[Modified by SlowCivicNick, 3:26 AM 8/26/2002]
Old Aug 25, 2002 | 06:38 PM
tinkerbell's Avatar
Default Re: Is this a clutch cable problem or something else ?? (SlowCivicNick)
so have you adusted it so it realeases where you want it to?
did it change again after that?
if it keeps changing - something needs to be replaced...
check it out.
t..
Old Aug 25, 2002 | 07:57 PM
bryant's Avatar
Default Re: Is this a clutch cable problem or something else ?? (tinkerbell)
you should be able to just put it where you like it. Set it a forget it. if something happens after that then you have other problems. probley cable is bad.
kid_02131
12
Nov 6, 2013 05:32 AM
DAmn
Jul 21, 2005 10:27 PM
NixTEG
Aug 25, 2002 06:30 PM
