96+ LS valve cover on 94-95 LS head question?
I know that the newer valve covers fit the obd-1 ls heads. My question is, what do you do about the PCV valve hole on the newer ls valve covers? On the obd-1 valve covers, the PCV valve is located on the intake manifold. Any suggestions?
I am not sure if i worded this right. Basicaly, I just got a new valve cover from 97 ls. My engine is a 95 ls with the different valve cover which has the PCV valve at the bottom of the intake manfold. I was trying to get some suggestions on what to do about using the PCV with the newer model ls valve cover
