Suspension & Brakes Theory, alignment, spring rates....
Questions about Ground Controls
Old Aug 17, 2009 | 03:44 AM
datssoled's Avatar
Default Questions about Ground Controls
I know you need the koni specificied ground control coilovers for the koni yellows, but what about the koni reds?
Do they use the same ground controls as the yellows too?
Old Aug 17, 2009 | 12:50 PM
TunerN00b's Avatar
Default Re: Questions about Ground Controls
The "reds" really won't accommodate a stiff spring rate, such as used in GC kits. They're really only OEM replacements, but can probably handle mild lowering springs.
If you want to use stiff spring rates, use appropriate shocks.
Apologies for not knowing the answer to the specific question asked.
Old Aug 17, 2009 | 01:25 PM
datssoled's Avatar
No problem.
Anyone know the answer to it?
So from what TunerN00B says, the ground controls off the Koni Reds are probably not the Koni specified Ground controls?
spoonef
Suspension & Brakes
Jun 3, 2007 10:18 AM
Goodbye My Love
Suspension & Brakes
Jul 12, 2005 08:32 PM
jakeiscool
Suspension & Brakes
12
Mar 23, 2005 02:16 PM
phantom_sol
19
Mar 5, 2004 08:52 AM
HondaJon
Mar 1, 2002 02:22 PM
