88crxhf body add 90 mpfi eng harness?help
Old Aug 16, 2009 | 07:32 PM
JOE BD-0's Avatar
Default 88crxhf body add 90 mpfi eng harness?help
I have a 88 crx hf and would like to add on my 90 mpfi engine harness to get the d16a6 running in this car. I know there is some re-configuring I need to do with at least a couple sensors or other wires (88=no ficv etc.). I've seen some of Jlicrx's charts on this special config stuff. He knows ALL this stuff...search only gives me a bunch of crap for sale....except jlicrx's posts......Thanks Again H-T......
Old Aug 16, 2009 | 07:35 PM
BiG ChOr!Zo's Avatar
Default Re: 88crxhf body add 90 mpfi eng harness?help
much easier i believe to keep your existing hf harness and take off plugs from the 90 mpfi harness...!!!
Old Aug 17, 2009 | 06:35 AM
JOE BD-0's Avatar
I don't have the 88 engine harness, only a 90. I need to mate these two together (88 car side harness to 90 mpfi engine harness), maybe adding the ficv and ficv wires to the 88 car harness if needed???
There are some wiring experts out there that can make this an easy plug and play deal?
Guys like Monotech, Rywire, Jlicrx, etc..Please help make this easy for this old racer...
thanks H-T.......
Old Aug 17, 2009 | 06:39 AM
losercruiser's Avatar
you are gonna need a hf harness for it 2 work try a junkyard if u aint got one or ebay
Old Aug 17, 2009 | 07:48 AM
jlicrx's Avatar
to use the Si engine harness with the HF chassis harness, you need to do this:
if you want to connect the Fast Idle Control Valve on the back of the Si intake manifold (you don't really need it) you need to do this:
run a wire from the blue wire on the FICV to ECU pin B2 (you need the 89-91 PM6 ECU as the 88 didn't have FICV and 88 ECU won't recognize it) - connect the black/yellow (power) wire from the FICV to the black/yellow wire at the EACV
-or-
when you repin the Si driver's side connector, you could move the blue FICV wire to location 3 on the connector and relocate the yellow wire at ECU pin C8 to ECU pin B2 - this will save running the additional wire from the ECU
Old Aug 17, 2009 | 12:19 PM
JOE BD-0's Avatar
Thank you Jlicrx sir...your info is always spot on.....
I thought I would need one side of one of the connectors, but after reading your post, maybe I don't need any connectors after all....
Thanks again....
Old Aug 17, 2009 | 01:49 PM
detuned's Avatar
if you can find an 89 hf harness, just re-used the hf dizzy on the a6.
Old Aug 17, 2009 | 05:23 PM
JOE BD-0's Avatar
There is no hf dizzy, the new car is a shell+body side harness (guessing hf model wire loom). I'm trying to use parts I already have to make it work to save another ef. This time it's a crx.
Jdmsolutions
May 2, 2009 09:08 AM
classciv
Mar 5, 2007 05:45 PM
90b20b4
12
Nov 6, 2006 12:03 PM
deftones0817
21
Feb 21, 2004 01:27 PM
deftones0817
Feb 14, 2004 11:05 AM
