Hondata 4bar MAP/GM 3bar MAP?boosted SOHC.
okay so im assuming 120bucks for the hondata map is a good deal but the gm map is half that and wonder if its really worth buying the hondata. im running a chipped p28 on my d15b. dsm inj, 50trim turbo, tial 38mm,.... so on normal setup. just wonderin if anyone has this hondata or gm and thoughts
Both sensors will work just fine.
One will simply bolt on & not require any splicing/soldering/vacuum lines.
I personally like the sensor that the hondata sensor uses a little better....
Correct. It takes the place of the original MAP sensor on the throttle body. The GM 3bar requires vacuum line plumbing and wiring of the pins for the sensor.
