NEED Answer for autometer A/F gauge
Old Aug 25, 2002 | 05:27 PM
integrx's Avatar
New User
Default People with helms HELP
ok people i have an 96 Integra Ls, i hooked up the purple wire from autometer to the PLAIN white wire going into the ecu. Now when i turn the car on it reads all the way rich. when i put it to drive and keep the brakes down it bounces from rich to lean and bounces back to rich. Did i hook it up wrong ? which damn wire is it for b18b obd2 ? BTW i did search and people say this wire and that wire. i need to know which wire is truely is for 96 integ ls.
[Modified by integrx, 6:28 PM 8/25/2002]
[Modified by integrx, 5:50 PM 8/26/2002]
Old Aug 25, 2002 | 08:57 PM
JDM_JON's Avatar
Default Re: NEED Answer for autometer A/F gauge (integrx)
thats the right wire....and thats exactly what my a.f ratio does too
Old Aug 26, 2002 | 12:42 AM
integrx's Avatar
New User
JUST FOUND OUT in the Haynes the white wire in 94-97 ECU is for the ckp / cyp sensor. Don't we suppose to hook up the purple wire of the A/F guage to the O2 sensor ? 94-97 ecu the O2 sensor would be either the O2S HTC= orange/black wire or O2S= white wire. For 98+ the white wire= PO2S(primary) and Org/Blk wire=PO2SHTC. PEOPLE WITH HELMS can you back me up on that ? <U>So are we suppose to hook it up to the O2S wire?</U>
[Modified by integrx, 1:45 AM 8/26/2002]
Old Aug 26, 2002 | 06:32 PM
integrx's Avatar
New User
ok guys i hooked it up to the red/white wire. It does not bounce around, and it reads rich when i start the car, then it goes to stoich later on; but the funny thingis it never goes to lean. some times it goes back to rich. is is this right?
[Modified by integrx, 1:17 AM 8/27/2002]
Old Aug 26, 2002 | 09:36 PM
blacksheep's Avatar
So is it supposed to oscillate back and forth, or is it supposed to stay steady on its reading? I want to know if mine is right.
Old Aug 27, 2002 | 12:20 AM
integrx's Avatar
New User
hey autometer instructions "when heavy load it should indicate rich. at crusing it will appear to be bouncing back and fourth between rich and lean." WTF, i mean i did hook it up to the oxygen wire right? can someone look in the helms and tell me the O2S wire color for the 94-97 integras.
oldskooljdm
Mar 26, 2005 10:01 PM
SpeedMonkeyRacing
Oct 20, 2004 01:33 PM
dbang003
14
Nov 29, 2002 07:32 AM
