spun bearing? bent valve?
Old Aug 16, 2009 | 01:19 PM
tuck1crx's Avatar
Default spun bearing? bent valve?
ok.. i have an ls vtec. i missed 2nd gear and brought it up to like 8k. (8k rev limiter) then it died on me. opened the hood and found that a bolt made its way into the timing belt cover (i have not center piece) and it ate up like half of the belt. the belt didnt full break so everything was still in time. i replaced the belt praying to god that was all that was wrong.
got the new belt on and started it up and it viberates really bad, wont idle, and feels like its not runnin on all cylenders. bent valves? spun bearinbg???
HELP ME!!! im gunna go comperssion test now
Old Aug 16, 2009 | 01:32 PM
dtme46's Avatar
Default Re: spun bearing? bent valve?
drain the oil and drop the oil pan and look for metal shavings.
Old Aug 16, 2009 | 01:42 PM
tuck1crx's Avatar
p1-190, p2-0, p3-210, p4-190
Old Aug 16, 2009 | 02:21 PM
tuck1crx's Avatar
oil is clean and no shavings in the oil pan.
Old Aug 16, 2009 | 02:34 PM
tuck1crx's Avatar
i lied.. a few lil shavings
Old Aug 16, 2009 | 02:51 PM
redsolturbo's Avatar
you have no compression in number 2 cylinder?
either you have dropped a valve or just bent one. pull the head
Old Aug 17, 2009 | 05:49 AM
Nick97hatch's Avatar
If its a new motor VERY fine metal in the oil is common. But yea you probably bent an exhaust vavle. That sucks, Dont forget to lap in your new vavles when you install them.
Go through and make sure all your bolts are tight, use Lock-tite on bolts too.
Old Aug 17, 2009 | 11:07 AM
tuck1crx's Avatar
its def an intake valve. i popped the valve cover and u can see the one spring in compressed,,, here we go again.......
accord96lx
Apr 10, 2014 01:10 PM
JDMFreakz
Jul 4, 2012 09:22 AM
xluben
Jan 1, 2007 02:42 PM
92integraVTECgsr
Dec 17, 2005 03:17 PM
Thirty-Nine
Jun 23, 2003 02:29 PM
