1993 coupe h22a swap
$4000.00
90k on chassis. H22a Closed deck JDM engine, HID's, front and rear upper and lower ties, c pillar tie, black on black, Ex model, power everything, 15' rims with almost new tires, tinted windows, chipped and tuned p28 with launch control, and full throttle shift, front and rear lip kit, energy suspension bushings, aftermarket rear lower control arms, Traction bar, custom adjustable front engine mount, Aluminum radiator, short ram intake, cd player and door speakers, ground control coil overs, short shifter, 5 speed, New clutch, timing belt, balance belt water pump, front and rear main seals new, 250 PSI on all cylinders. Does not smoke or leak. Runs very good. replaced front brakes 6k ago, clean title. Will trade for something all wheel drive. Call Or text me 425-367-9369
add on $500.00 if you want the amps, jl sub, and Polk audio rear deck speakers.
