Help please!!!
Old Aug 16, 2009 | 01:07 PM
charlieboyhonda's Avatar
Default Help please!!!
Hi guys need help I recently rebuild my engine d16a6 and put p29 pistons .40 milled head it has gas regulator, header 4-2-1 d16y8 head gasket stock ecu pm6 all new cold spark plugs everything and it fires but its very very rich in all cilinders and its stalls about 30 seconds i pull out all spark plugs and they are all wet it doesnt have the check engine ligth on but when I disconnect a sensor it turns on but when a try to check the ecu code it doesnt blink just stays on help guys please I need the car is a civic hacthback 90 SI because my daily drive car got stolen
Old Aug 17, 2009 | 06:45 AM
dephtone's Avatar
Default Re: Help please!!!
Solid light on the ECU, assuming it's OBD0 means the ECU is no good. Have you tried removing the hazard fuse and trying to pull any codes then?
I don't think you will be able to run the car with a stock ECU, p29 pistons + .40 milled head, thats adding ~2 points of compression to your motor. You are looking at ~12.5:1 compression. This part is just as an FYI
What plugs are you running?
90integ
Jun 7, 2011 10:15 AM
Edwin909
Feb 12, 2011 04:42 PM
DC2-JRSC'd
15
Aug 3, 2004 06:26 PM
WCI
Nov 9, 2003 08:17 PM
South Bay Surfer
Dec 30, 2002 09:48 PM
