Are 3" charge pipes too big?
Old Aug 16, 2009 | 11:17 AM
1992db2's Avatar
Default Are 3" charge pipes too big?
Hey hond-tech.....
So im boosting in a DA chassis, I was wondering if 3" charge pipes would be too big. Im asking because one of my friends is selling his charge pipes at a pretty good price. Or should i just find myself some 2.5" charge pipes?
So what would be better. 3" or 2.5"?
set up:
b16
8:1 pistons
eagle rods
turbonetis 60 trim
tial 38mm W/G
fab-works ramhorn
3" D/P
1000cc inectors
ported n polished
ITR valvetrain and cams
Old Aug 16, 2009 | 11:33 AM
96 GSR-T's Avatar
Default Re: Are 3" chage pipes too big?
2.5" is all you need, I saw no difference in responce when I went from 2.5" to 3" but then again I had half the piping with the 3" setup.... just a cold side.
Old Aug 16, 2009 | 01:19 PM
1992db2's Avatar
so will 3" hurt?
Old Aug 16, 2009 | 01:36 PM
fishieman's Avatar
Originally Posted by 1992db2
so will 3" hurt?
Probably takes the compressor longer to charge up the air to the IM.. decrease in spool time maybe?
Old Aug 16, 2009 | 01:37 PM
1992db2's Avatar
crap. i wouldnt want that to happen.... makes sence though
Old Aug 16, 2009 | 01:40 PM
turbociv910's Avatar
my DA had 3" piping, 81mm lsvtec, gsr cams, gt35r(.63)spooled 18 psi at 5500
Old Aug 16, 2009 | 01:52 PM
Bailhatch's Avatar
I doubt it would hurt response and it won't hurt power.
Old Aug 16, 2009 | 03:05 PM
1992db2's Avatar
so 3" wouldnt hurt power or responce?
does anybody think otherwise?
Old Aug 16, 2009 | 03:17 PM
Alfa Turbo's Avatar
Default Re: Are 3" charge pipes too big?
Will hurt response.
Old Aug 16, 2009 | 03:21 PM
eggie75's Avatar
just be a pita to route the pipes.
Old Aug 16, 2009 | 03:39 PM
91jdmhatchback's Avatar
3" is just overkill, no need for it at all. think about it...
Old Aug 16, 2009 | 04:20 PM
jdm inc's Avatar
you will b fine with 2.5 with you setup....Why so low of a compression.
Old Aug 16, 2009 | 06:08 PM
1992db2's Avatar
I got the bottom end for dirt cheap, I had the turbo kit at home so i figured why not give it a shot. Is the compression really too low?
Old Aug 16, 2009 | 06:12 PM
1992db2's Avatar
So some of you guys think its too much?
I was going to do 2.5" charge pipes but thats going to run me about $700 with the intercooler. A friend of mine is sellin a 3" set up with a nice intercooler for $275.
But if its going to hurt power or responce i will spend the couple extra bucks and pay the $700
Old Aug 16, 2009 | 06:40 PM
boost4life's Avatar
hope this can help you.
https://honda-tech.com/forums/forced-induction-16/when-does-2-5%22-intercooler-piping-start-become-restriction-2409417/
Old Aug 16, 2009 | 06:49 PM
cjordan's Avatar
wow that link had alot of useful info in it, worth everyone reading for sure...
Old Aug 16, 2009 | 07:21 PM
i fit the sparco 750HP core under my 91 da bumper. all 3" piping
Old Aug 16, 2009 | 09:13 PM
JRSC4me's Avatar
why not get the 3" intercooler for cheap, then just buy the 2.5 piping and reducer couplings
Old Aug 17, 2009 | 01:09 AM
jhammond_82's Avatar
Reject Papi
i'm using 2" from turbo to the intercooler, and then 2.5 up to the intake manifold. 3" for my setup would be overkill.
96 GSR-T's Avatar
Its pretty low, def no need for it to be that low, but you will be ok.....
Old Aug 17, 2009 | 02:25 AM
Bailhatch's Avatar
Same deal as 2.5" vs. 3" charge pipes...you won't ever feel any signifigant difference between 9:1 and 8:1. Tons of people run that CR with good results.
Old Aug 17, 2009 | 03:51 AM
Tjabo's Avatar
This setup is just asking for some serious boost with that compression ratio and those big charge pipes!
Old Aug 17, 2009 | 04:51 AM
93supercoupe's Avatar
just buy the 3inch piping/IC and save youelf the money.
Old Aug 17, 2009 | 07:31 AM
Schister66's Avatar
Man U FTW
You're going to increase spool time and make less torque with 3" piping versus a 2.5" setup. This is due to the larger volume in the piping which must be filled before the IM can see boost pressure. Also, the larger piping will move a given volume of air with less speed than a smaller diameter pipe which will decrease your torque numbers. You want to maintain air velocity and flow without incurring mass turbulence by running too small a pipe. There is a great thread in the FAQ regarding this...it shows the CFM needed to make a certain amount of power and how that equates to flow speed and turbulence. You should check it out before moving forward...
EDIT: Here's the thread...
https://honda-tech.com/forums/showthread.php?t=2409417
Old Aug 17, 2009 | 08:46 AM
96 GSR-T's Avatar
^^^^ that thread really goes in no specific direction IMO.....
