FS: JDM B16a
I have a JDM b16a up for sale. It came from either a CRX sir or Integra xsi/rsi. It's obd0, I will be giving two wiring harnesses with it. I was planning to put it into my DA but I would rather go with a GSR.
The block is in great condition. Still has the p30 pistons and rods. I replaced the water pump and tensioner. Alternator in like new condition. Oil pan gasket was also replaced, block is super clean. What' in the pictures is what it comes with, I do have some extra plastic covers for the timing area lying around.
The head is complete minus the distributor. I was planning to convert it to obd1 so I never bothered to pick a distributor up. The VTEC solenoid is not in the pictures but one is included, same with the last cam cap that is missing in the pics, it is included.
I also have used b16 head studs, but would recommend replacing them since they were run, ARP's are stronger so I would suggest picking those up. The guy who had the motor before me started to cut the valve cover for exposed camgears, but gave up. Nothing wrong with it but you can finish the job or replace it. I will also include the STR anodized blue Fuel rail that's in the pictures. Other than that everything is there for the head.
I'm asking $700obo, send me a pm if your interested
I'm located in the Northern end of Rhode Island
http://i5.photobucket.com/albums/y17...ale/motor1.jpg
http://i5.photobucket.com/albums/y17...ale/Motor2.jpg
http://i5.photobucket.com/albums/y17...ale/Motor3.jpg
http://i5.photobucket.com/albums/y17...ale/Motor4.jpg
http://i5.photobucket.com/albums/y17...ale/Motor5.jpg
http://i5.photobucket.com/albums/y17...ale/Motor6.jpg
http://i5.photobucket.com/albums/y17...ale/Motor7.jpg
http://i5.photobucket.com/albums/y17...ale/Motor8.jpg
http://i5.photobucket.com/albums/y17...ale/Motor9.jpg
http://i5.photobucket.com/albums/y17...le/Motor10.jpg
http://i5.photobucket.com/albums/y17...le/Motor11.jpg
http://i5.photobucket.com/albums/y17...le/Motor12.jpg
http://i5.photobucket.com/albums/y17...le/Motor13.jpg
http://i5.photobucket.com/albums/y17...le/Motor14.jpg
http://i5.photobucket.com/albums/y17...le/Motor15.jpg
http://i5.photobucket.com/albums/y17...le/Motor16.jpg
http://i5.photobucket.com/albums/y17...le/Motor17.jpg
http://i5.photobucket.com/albums/y17...le/Motor18.jpg
http://i5.photobucket.com/albums/y17...le/Motor19.jpg
