RBC vs PRC intake manifolds
Wondering what car a RBC intake manifold for the k20 comes out of??? I was told is was in the 06 Civic Si.... is this correct?
I have a DC5 and want to do the RBC manifold because I need to buy a new one either way. Is there a noticable gain between these two intake manifolds (PRC vs RBC).
Also, I know my throttle body will not work with the RBC. Can I use the throttle body of a 06 SI, or is it better to use an adapter plate.
THANKS FOR THE HELP!
you also will have to cut the rbc intake manifold to fit correctly onto your motor if u have a k20a2 k20a or k20z1 ...
and yes the rbc will give you a noticable increase in power ... i'd say a good 5 or more horsepower ... check out the new skunk2 intake manifold its suppose to have much better flow than the rbc and is direct bolt on.. u can also use your prb throttle body without a spacer...
Civicek000
Oct 23, 2016 07:07 PM
blacK_Dc4
Northern California (Sales)
Jun 17, 2013 09:19 AM
