Need help to see if these will fit my hatch...
Old Aug 15, 2009 | 04:29 PM
JDMADD1CT's Avatar
Default Need help to see if these will fit my hatch...
Ok, i have a '98 Civic hatch currently on 16x7 +33 offset rims w 195/45's & a moderate drop(car sits right above the tire...tire isnt tucked in the fender w crazy camber), not slammed & they fit fine. no rubbing issues at all. i'm looking into possibly getting a set of 15x8 +32 offset wheels & wanted to know if there would be a fitment problem, like rubbing etc? i can always get wider front fenders/fender flares if there would be that much tire sticking out (btw, i'm looking at 195/45 or 205/45's), but what about the rears? i know anything is possible after seeing some of these super low offset wheels on EK's, but i'm not looking at doing major modifications to my fenders besides a slight roll or pull. if they'd fit the front & rear w/o major modifications, i'll get them. if not, i'm sticking w what I have. thanks for any help
Old Aug 16, 2009 | 04:31 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Need help to see if these will fit my hatch...
No, you can't use 15x8 wheels on your car, and you're considering the wrong tire sizes too. For 15" wheels on your car, you need 195/55-15 or 205/50-15 tires. 195/55-15 can only be mounted on wheels 5.5-7.0 inches wide, and 205/50-15 only on 5.5-7.5 inches wide. Either tire size can't be mounted safely on 15x8 wheels.
Incidentally, on your 16" wheels, you should be using 205/45-16, not 195/45-16. And 205/45-16 shouldn't rub with a moderate drop, either.
hondapeeler
Dec 2, 2010 08:59 AM
blackstar
Jan 1, 2007 08:34 PM
JDM SLICK
Apr 13, 2006 02:38 AM
WHITE DEATH
Dec 30, 2004 02:08 AM
SantaCruz92Si
Jul 22, 2003 01:36 PM
