New Pics w/ New Camera
The 7M-GTE has SARD fuel injectors, Lexi AFM housing, HKS air filter, aeromotive AFRP, hi-boost walbro supra fuel pump, j-pipe delete, aluminum FMIC, all 3" piping w/silicone couplers, straight exhaust, HKS boost controller (7psi and 15psi), HKS turbo timer, and NGK Wideband.
Should be good for about 380whp at 15psi (the truck will spin its 32" tires through 2nd)
The car is done, I just need to clean up a few things, refit some parts, repaint other parts, and mess with the interior a bit.
Exterior and performance modifications are finished, I am very happy with how the car drives and looks right now.
Thank you for the kind words.
Nice....... love ur NSX. has Gran Turismo sex appeal.
Diggin ur toyota swap as well..... turbo Diesel would be the shyt for that 4x4 truck tho!!! a 2L-TE would be the ish!!!!!!!! detroit lockers?
The 7M-GTE is a DOHC 3.0L engine that is making four times that power in its current iteration.
The diesel is a standard option in other countries for this truck... the 7M-GTE supra motor will smoke Ford lightnings all day, and gets better fuel economy than the 22RE that came out of the truck (18-19mpg, vs 16-17mpg); for off-roading, none of this matters, the 22RE is more than adequate with low range gearing, but driving around on the street, 100hp doesn't cut it for a truck (you will be passed by suburbans, etc.)
It's a Toyota e-lock swap from a Tacoma, the housing is custom to allow this diff to work with the truck's rear axles; there is a Lockright installed on the front axle.
miiek
May 15, 2005 10:03 AM
ATS*Mark
Oct 17, 2003 04:09 PM
