need opinions on a possible purchase
would it be worth getting a comptech rear lower tie bar for my 2000 gs-r? it has stock suspension, but i will be adding eibach sportline springs in the near future.
I think a Comptech Swaybar/Tie Bar combo....
but it's like 300.
But since you are going to lower your car, then I would consider some shocks/struts and a camber kit depending on how low you lower it.
but it's like 300.But since you are going to lower your car, then I would consider some shocks/struts and a camber kit depending on how low you lower it.
60 bucks from AHmotor...ITR rear sway bar works just as well as the Comptech....I just got mine and holly cow...is there a huge difference
i have a 2000 GSR
i have a 2000 GSR
i will be getting the itr sway bar but in the future. and i will be getting shocks for my springs. but i'm asking for the time being. would it be a wise invest for the tie bar for the future. i've found it for a good price and wanted to see what your opinions on it are.
probably can't go wrong with the comptech tie.
consider that springs, shocks, and swaybar to be the meat of your suspension. those items are the biggest contributors to your car's overall handling capabilities..at least that's what i believe.
i'd do springs and shocks at the same time...then swaybar..then worry about your bars
just offering a suggestion
besides, itr swaybars are on national backorder right?..order one now and in the meantime ..work on getting new shocks/springs..
[Modified by lshobo, 6:40 AM 8/26/2002]
