89Si Cranks but wont start. no spark apparently?
Old Aug 15, 2009 | 12:16 PM
C-RICKS's Avatar
Default 89Si Cranks but wont start. no spark apparently?
as posted. I tried distributor from 90si and new plug wires and still no go. What wire from the ignition through fuse box and out to distributor should i be looking for to check for breakage or short?
Old Aug 15, 2009 | 12:19 PM
.Manny.'s Avatar
Touching My Member
Default Re: 89Si Cranks but wont start. no spark apparently?
are you getting fuel as well? Listen for the fuel pump to prime when you put the key in the "on" position without starting the car. Do you hear 2 clicks from the main relay to the bottom left of the dash?
Old Aug 15, 2009 | 01:00 PM
C-RICKS's Avatar
GREAT suggestion! The pump is priming cause i can hear the hummmmmm. But now that you mention it, i dont recall hearing the main relay. I 'll jam home and try a diff, main relay and see if that works.
Thanx,
Rick
Old Aug 15, 2009 | 03:34 PM
ewok1's Avatar
I just hsd the same problem..i thought it was all that and it was just my main relay under my dash..i pocket that at the junk yard..see if thats it..my ride crank but wouldnt turn over..now its fine
Old Aug 15, 2009 | 06:05 PM
dacrxguy's Avatar
When you car cranks it is "turning over"
anyways op the black yellow wire in the two plug clip in the distributer is where you should be looking. Is there any codes being thrown?
Brand
21
Sep 8, 2022 09:39 AM
CR-Ricks
Jul 17, 2013 03:09 PM
mynameizstitch
26
Aug 5, 2012 04:33 PM
fenix4o9
11
Jul 18, 2007 04:06 PM
Ep1dem1c
Jul 3, 2007 06:49 AM
