90 civic b18 turbo, motors, turbo parts, and more
Old Aug 15, 2009 | 11:02 AM
drumritter258's Avatar
Default 90 civic b18 turbo, motors, turbo parts, and more
Alot of the stuff I have below has accumlated over this EF project that is also listed on here. I need to get rid of alot of this stuff to help pay for the apartment I am going to be sharing with my GF of 4 years. I can be flexible on some of the stuff but try not to lowball me to bad guys lol. I will be getting pictures of everything this weekend so save the posts. If you have any questions about anything pm me or post in here, I check it daily.
Engines:
OBD1 B16a Long block. Includes head, complete manifold, bottom end (needs rebuilt), distributor, and valve cover (yellow). When I bought this I was told the bottom end will need rebuilt, but everything else is legit B16a parts. Make an offer on the long block or if I get enough interests I will seperate it.
Engine harness for a B-series Engine in a EG chassis. This came off of the B16a when it was in a 94 coupe. It is uncut and real clean. Will take 60 plus shipping.
The FUN list:
D16z6 head. It is bare but the surface is not warped. Good for someone looking to build a head. 20 plus shipping
D16a6 head. The valve head have some surface rust on them from sitting in my truck but other than that just needs a good cleaning and its good to go. Make an offer.
I have 2 Brand new Motorola 2.5 Bar map sensors. These map sensors help you achieve that go fast want. lol They both have 6 inch pigtails to wire up to your stock harness. 35 shipped each
Brand New CAI Air filter. Cotton filter (Red) you guys know what im talking about. Brand new..Got it with my kit but didn't fit. Make an offer
Stock EF suspension with forks. Idk if someone might be interested in this but make an offer.
D16z6 bare block. This baby is bare and painted blue. I was going to build a single cam but went with something bigger. Will be a bitch to ship but if the buyer is willing to pay the shipping costs then I will ship it. 40 plus shipping
LOJACK system. Comes brain unit, battery, and you need to buy another antenna which can be purchased from LOJACK. I got this system in my Del Slow, but took it out when I bought it. Im not sure what the deal is on transferring names, but Im sure it can be done. Ill take 40 plus shipping.
T3/T4 turbo to manifold gasket. 10 shipped
38mm wastegate dump tube. 25 shipped
Delsol 1 pc Headlights. I bought them off Ebay to use but my car is too shitty for them. They are brand new and haven't been on a car. The headlights are black housing with the amber side where the turn signal is at. I would like to get 75 and your stock headlights/corner lights.
Knock-Off EF/ED Spoon style POWER mirrors. I bought them from a friend to put on my hatch but I could care less about it lol. I would like to get like 25 shipped OR if someone has a stock passanger side mirror Then I would take like 10-15 and your mirror.
Stock 88-91 Civic corner lights. They are in good shape, switched out for ambers. Would like 25 shipped.
Stock B18 header with 1 wire O2 sensor. All was in good working order when removed. Make an offer
Energy Suspension Poly Master Bushing kit for 88-91 civic/crx. The kit is only missing the Front sway bar endlinks and strut top bushings. I would like to get 60 plus shipping.
Stock OBD0 PR4. I would take 50 plus shipping.
Also I would like to see what I can get for my 1990 civic hatch. It has the following mods done to it:
B18a1 bottom end with a B18b1 Head
GSR YS1 Transmission with a 6 puck SPRUNG clutch and Fidanza 8lb flywheel
DA Front lip for the rear bumper
Amber corners
MK3 VR6 front lip
EK sideskirts (havent put them on yet)
OEM Carbon fiber hood (havent put it on yet)
Chipped PR4 with a tuned basemap. Can up the boost with bigger map sensor
Battery relocated to the back
Wire tuck to the max
Hasport mounts
Hasport Shifter linkage
Skunk 2 Dual Bend shifter
Energy Suspension Shifter bushings
Ramhorn manifold, 38mm wastegate 10 psi spring, 54 trim turbo, with open downpipe
Civic radiator and fan on gangsta lean
Thick *** intercooler, but I might have a bigger one to throw in.
TurboXS RFL BOV
T bolt clamps and 90 deg coupler from Verocious
Oil pan tapped and custom line made by Verocious
Sitting on Tokico blues, with adjustable coilovers
The bad: It would be faster with something bigger than a POS 13 in wheel. I put some Radials on it just for ***** and giggles and kept up with a 12 sec car. So it needs some bigger tires. Would recommend a traction bar kit to help with wheel spin. The passanger side quarter panel will need to be pulled or replaced. This doesn't affect the way the car drives though.
MAKE AN OFFER. Like I said I will get pictures this weekend.
Old Aug 15, 2009 | 11:06 AM
1995Civiccx's Avatar
Default Re: 90 civic b18 turbo, motors, turbo parts, and more
pm'd
Old Aug 15, 2009 | 12:42 PM
wasabivtec's Avatar
you dont have an engine harness for an ef si by chance do you?
Old Aug 15, 2009 | 09:28 PM
ill get back to you on that. A friend of mine just picked up another EF so i can see if he has something.
Old Aug 16, 2009 | 10:44 AM
bump bump bump
Old Aug 18, 2009 | 05:37 AM
bump. need this **** sold
Old Aug 18, 2009 | 06:47 AM
92egvx's Avatar
bump...
Old Aug 30, 2009 | 10:13 AM
bump. come on people
Old Sep 10, 2009 | 10:55 AM
bump!
Old Sep 10, 2009 | 11:10 AM
speedooo's Avatar
How much are you looking to get for the ls hydro trans? And do you know what year it is and how many miles are on it?
Old Sep 10, 2009 | 10:35 PM
its been sold. sorry man. BUMP!
Old Sep 11, 2009 | 10:09 AM
BUMPPPP!
Old Sep 21, 2009 | 10:48 AM
bump
Su1c1dek1ng
Aug 30, 2011 12:14 PM
Murk 'EM
Apr 30, 2009 08:15 PM
crxdelsolvtec
Jan 16, 2005 10:31 PM
