B16 producing white smoke?
Old Aug 15, 2009 | 09:33 AM
chad122's Avatar
Default B16 producing white smoke?
I recently done a motor swap w/ a b16a into my 98 civicLX. It has a 65mm edlebrock tb, skunk2 pro series intake manifold, hondata intake mani gasket, dc sport header, evo2 exhaust, and chipped p28 on crome. Has a NEW head gasket. It was idling high w/ no check engine light(around 2K). I put the intake manifold on myself and thought I rewired everything right.
I took it for a drive down the street yesterday ( bout 90 degree weather) and at the first stop light it started to get hot, I pulled over and turned it off. Started to go back home when I could see white smoke behind me, pulled over again.
When I started the car this time the car was smoking alot of white smoke from the exhaust. Could it be in the intake manifold? The motor only has 35K on it and I changed the oil 3 days ago and the oil still looks super clean. Help! thanks
Old Aug 15, 2009 | 09:46 AM
DDTECH's Avatar
Default Re: B16 producing white smoke?
2k idling? vac leak.sounds like you also crossed a hose somewhere.
Old Aug 15, 2009 | 10:00 AM
chad122's Avatar
I just really hope its nothing internally.
Old Aug 15, 2009 | 11:28 AM
Top Ramen's Avatar
White smoke = coolant. Its getting water in there somehow. How confident are you about the head gasket install?
Old Aug 15, 2009 | 11:51 AM
chad122's Avatar
Come to thank of it......
The guy who was SUPPOSED to do my swap screwed up everything so he probably screwed that up to. I'll just consider that gasket screwed.
Old Aug 15, 2009 | 12:05 PM
DDTECH's Avatar
leakdown test to be sure..
if it is a HG leak, i'd let it run, and rev it, if theirs bubbles in the radiator considering it gone, thats if there's a leak around the water jacket which is cyl 1-4
Old Aug 15, 2009 | 12:15 PM
chad122's Avatar
God forbid I cracked a sleeve. I'll be done with it........its gonna be one expensive bond fire. lol
MGX
Sep 4, 2011 10:01 AM
vonttcha
Nov 11, 2009 06:54 AM
ge_ej1
13
Jan 5, 2008 10:24 PM
matix
Sep 13, 2006 06:36 PM
chelude
May 25, 2004 01:05 PM
