can i add 7 amps?
Old Aug 15, 2009 | 08:03 AM
85's Avatar
85
Default can i add 7 amps?
I've got an 03 919. do you think adding an extra 7 amps to the power system will be unfeasible? if not, how can i make it work? I've got the turn signals and tail light switched to LED so I'm sure that helps a little.
Old Aug 18, 2009 | 05:51 PM
kneeslide's Avatar
Default Re: can i add 7 amps?
Is it an intermittent load, or continuous?
Some peole fit those heated grips, find out what amps they are, or if they require fitting a relay?
EG_Warped
Audio / Security / Video
Jun 30, 2008 03:01 PM
norcalbayboy
Lighting
Apr 29, 2008 06:51 PM
shyboy817
52
Aug 4, 2004 05:05 PM
XDEep
12
Apr 22, 2003 08:09 AM
