cv shaft removal
Old Aug 15, 2009 | 01:03 AM
kornkid21792's Avatar
Default cv shaft removal
the part that goes to the brakes i cant get off its like in the middle of the disc brake. i was told to just hammer it out but i dont wanna break it i didnt it a coup times but it didnt budge
Old Aug 15, 2009 | 06:02 AM
street_ride14's Avatar
Default Re: cv shaft removal
Originally Posted by kornkid21792
the part that goes to the brakes, i cant get off
goodluck
Old Aug 15, 2009 | 06:11 AM
Quan_97SH's Avatar
Use a plastic hammer. you did remove the axle nut right?
Old Aug 15, 2009 | 06:39 AM
lude98SH's Avatar
You did you pop the lower balljoint, right ?
Old Aug 15, 2009 | 09:28 AM
hmm. the other end that went into the engine is off what do you mean balljoint
Old Aug 15, 2009 | 09:45 AM
lude98SH's Avatar
So you removed the inner side first, the side that goes into the diff or int shaft ?
Old Aug 15, 2009 | 09:46 AM
yes. i think its the int shaft the one on the passenger side
Old Aug 15, 2009 | 09:57 AM
^^ no, the passenger side goes directly into the diff.
Old Aug 15, 2009 | 10:05 AM
TheCivicMafia's Avatar
Please download helms. Or buy a manual some where.
Old Aug 15, 2009 | 10:27 AM
o hahah well how do i get it off. and dude i do have a manual i already looked and read it thats why im on here
Old Aug 15, 2009 | 10:52 AM
and the manual was no help ? .. anyways, for ease of removal place axle back into tranny, place tire back on, lower car to ground, remove axle nut on hub, raise car back up, remove tire, remove axle from tranny side, then hit axle from hub side with hammer, if done right axle should come out from car. Replace, and retorque.
Old Aug 15, 2009 | 01:21 PM
yep and i did that i hit it but nothing no budge or anything
Old Aug 15, 2009 | 05:39 PM
The AW Alchemist's Avatar
I used a sledge hammer one time, and that bitch flew out.
Old Aug 15, 2009 | 11:14 PM
we tried that its not working
Old Aug 16, 2009 | 03:05 AM
i cant get it off
go to the gym
Old Aug 16, 2009 | 08:25 AM
Old Aug 16, 2009 | 09:08 AM
vinuneuro's Avatar
Are you trying to get it out of the hub or the intermediate shaft/diff?
Old Aug 16, 2009 | 10:00 AM
313hitman's Avatar
mine was stuck like that b4. I had to end up replacing the knuckle because the retard b4 me welded it on.
Old Aug 16, 2009 | 10:32 AM
tryn to get off off the disc brake. well damn what u think i shld do
Old Aug 16, 2009 | 10:37 AM
vinuneuro's Avatar
Did you get the spindle nut off?
Old Aug 16, 2009 | 11:00 AM
yes sir i did
Old Aug 16, 2009 | 11:24 AM
vinuneuro's Avatar
And you've separated the lower arm balljoint to swing the spindle outward?
If yes, just start hitting the axle with a hammer. Doesn't have to be too hard, but do it repeatedly and it'll break free. Try spraying some Liquid Wrench in there if it's not budging (make sure you don't get any on the rotor).
Old Aug 16, 2009 | 02:25 PM
yes. and weve been hitting it and sprayn pb but it still wont budge
Old Aug 16, 2009 | 03:51 PM
Acidcrakker's Avatar
cut it off. And replace the axle and or rotor
Or
If you have access to a torch, you can heat it up and than try to break it free.
Old Aug 16, 2009 | 04:09 PM
weve heated it and it hasnt worked
