HELP! FUEL LEAKING FROM FUEL CONNECTION
I just changed out some fuel lines from the firwall to the fuel pump...
The connection at the firewall is leaking... i have tightened the bolt as tight as it can get but i am still leaking little drop lets of fuel.
Is their a seal i am supposed to use when screwing the bolt back on?
fyi
89 crx DX
fyi
89 crx DX
but ya, its just the fuel hose coming throught the firewall and then the little hoes that goes to the fuel fileter.... the firewall connect is just not good enough and is leaking ....
should i use somje typ of sealant or glue....
anothersickhatch
Nov 7, 2007 05:20 PM
