Need help QUICK...installing used Gground Control right now! thanks...
Old Aug 25, 2002 | 03:41 PM
JDM_ITR's Avatar
Default Need help QUICK...installing used Gground Control right now! thanks...
I need to know which springs go in the front and which in the back....
44/96 ( the short spring with less coils)
29/96 (long spring with more coils)
Im guessing the spring with more coiles goes in the frong to accompany the heavier front end....but the lower #(29) threw me off. I thought the higher number would go in the front. Anybody know for sure?
Old Aug 25, 2002 | 04:24 PM
ingrate's Avatar
25 Year Member
Default Re: Need help QUICK...installing used Gground Control right now! thanks... (JDM_ITR)
what are all of the #'s printed on the spring?
Old Aug 25, 2002 | 04:37 PM
AcuraRacer112's Avatar
Default Re: Need help QUICK...installing used Gground Control right now! thanks... (In7egrity)
the numbers should be printed on the spring but generally I dont know how you wanted your car set up but my went stiffer in the rear which would be your 44, and the less stiff up at the front which is the 29 but that was my set up.....less siff in the front and stiffer in the rear but the numbers are printed on the coils themself, they are in the hunderds aka for me 550 and 450....take a look, and good luck
Old Aug 25, 2002 | 04:42 PM
neo1z's Avatar
Default Re: Need help QUICK...installing used Gground Control right now! thanks... (AcuraRacer112)
the long ones are typically in the front.
-rob
Old Aug 25, 2002 | 05:33 PM
Deluzional's Avatar
I just put mine in a couple days ago, the fronts are the long springs
kasperxtcy
Suspension & Brakes
Feb 16, 2008 07:59 AM
11psiTurboSI
15
Jul 8, 2004 09:29 PM
Cru Jones
Apr 10, 2003 06:14 PM
JDM_ITR
Aug 25, 2002 04:25 PM
JDM_ITR
Aug 25, 2002 03:44 PM
