EGR problem help please
Old Aug 14, 2009 | 05:45 PM
Forrester's Avatar
New User
Default EGR problem help please
Hi,
I have a "check engine light" on with my 1988 accord LXi auto trans. i read some about the codes on ECU, i got 12 short flashes which means the problem is the EGR system. any suggestion yo fix that problem??
Thank You!
Old Aug 15, 2009 | 07:04 AM
street_ride14's Avatar
Default Re: EGR problem help please
check to see if you vacuum port is plugged into your EGR valve, check to see if your electrical connector is in good condition and plugged into the EGR valve. You could also check to see if there is enough vacuum to to pull the EGR valve open. If all checks out alright, you have to replace EGR valve.
Old Aug 15, 2009 | 05:51 PM
96redexcivic's Avatar
Icon6 Re: EGR problem help please
I agree with street_rider14, Good luck
niccook
Sep 11, 2011 12:38 PM
swertepinoy
Oct 12, 2009 02:50 PM
brianr67
Jun 2, 2005 10:06 AM
GencivicIII
Nov 22, 2002 09:40 PM
